1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subclassing Pyepics epics.motor doesn't work as expected
To: Terry Cornall <[email protected]>
Cc: "[email protected] \([email protected]\)" <[email protected]>
Date: Wed, 28 May 2014 21:46:33 -0500
Hi Terry,
Sorry for the trouble.  The Device classes in pyepics, including the Motor class, are a little unusual in that they override
__getattr__() and __setattr__() for getting/setting instance attributes that are internally mapped to fields of the appropriate device.   That is, one can do
    >>> from epics import Motor
    >>> m1  = Motor('XXX:m1')
    >>> print m1.VAL   # gets VAL field
    1.000
    >>> m1.VAL = 2.0   # puts to VAL field
    >>> print m1.RBV
    2.000
Since there are many fields in the Motor record, many of which aren't needed for most use cases, a Motor object does not try to connect to all fields at initialization but instead trie to connect to a particular field only when necessary (ie, as late as possible).   Currently this means that __getattr__() and __setattr__() will treat any unknown attribute as a potential PV, so that
   >>> print m1.FOO
will hang for a while, trying to connect to 'XXX:m1.FOO', eventually returning None.
Right now, the list of "attributes to not convert to PVs" is hardwired into the Motor class (and other Devices too), and I don't think it can be easily altered by a subclass.  At least, I don't see an easy way to do that.
It would certainly be reasonable to change this behavior.  I think it might be preferable to have an explicit list of attributes that will be converted to PVs rather than trying to convert every unknown attribute to a PV.  That would better allow subclassing, and avoid silent hanging on typos. This might take a little effort, but is probably worth it.
--Matt
On Wed, May 28, 2014 at 7:33 PM, Terry Cornall <[email protected]> wrote:
Hi All.
I’ve been trying to subclass the Motor class in Pyepics, so I can add my own variables and methods to it, and I’ve run into problems.
Adding new methods seems to work just fine, but I find a strange problem when I try to add new ‘instance variables’ to my subclass.
They all end up having value ‘None’ if I add them after doing the __init__ of the base Motor class. Worse, if I try to define
them before I call the epics.Motor.__init__(), I get an exception from motor.py. This is not normal Python behaviour, as far as I know, and I’ve added code to test that I can subclass this way with a ‘simple’ python class, as shown below.
Any ideas what I am doing wrong, or why epics.Motor can’t be subclassed in this way?
Any suggestions as to how I can subclass it and add my own variables, or why I shouldn’t?
I suppose an alternative would be to make a class that contains an epics.Motor object rather than subclass it.
Terry
import epics  #get the Motor class (and everything else) from Pyepics
class myBaseClass():   #make a simple base class so I can test that subclassing works as expected
    def __init__(self,*args,**kwargs):
        self.baseVar=kwargs.pop('mssg')  #have some variable just so we aren't empty
class myClass(myBaseClass):     #subclass myBaseClass
        self.before_init_base_instance_variable=1               #add an instance variable before I init base class. This works
        myBaseClass.__init__(self,*args,**kwargs)            #init the base class
        self.new_instance_variable=1000                        #here’s a new instance variable that I want in my subclass
        self.another_new_instance_variable=2000      #here’s another new instance variable that I want in my subclass
class myMotor(epics.Motor):     #subclass epics.Motor
    #    self.before_init_instance_variable=1                  #This would get an exception from motor.py, so I comment it out
        epics.Motor.__init__(self,*args,**kwargs)          #call the epics.Motor ‘s __init__ to set it up
        self.another_new_instance_variable=2000      #here’s a new instance variable that I want in my subclass
c=myClass(mssg='fred')
print c.before_init_base_instance_variable                   #This works.
print c.baseVar                                               #print the variable in the myBaseClass just to show it worked
print c.new_instance_variable                       #access the variable I added. It works
print c.another_new_instance_variable            #access the second variable I added. It works
c.new_instance_variable=3000
print c.new_instance_variable                    #see if writing to it worked. It does
m=myMotor('SR10BM01DMC05:MTR01')            #create an instance of my subclass, based on epics.Motor
# print m.before_init_base_instance_variable              #Just trying to define this causes an exception so it’s commented out
print m.new_instance_variable                                      #try to access the variable I added, get 'None'
print m.another_new_instance_variable                     #try to access the second variable I added, get 'None'
m.new_instance_variable=3000
print m.new_instance_variable                            #see if writing to it worked. Get 'None'
This is what I get when I run the code.
1                  #this is from the instance variable I added before calling myBaseClass.__init__ and it works
Fred           #this is the variable in the the myBaseClass and it is initialised as expected.
1000       #The next three are instance variables I added to my sublass based on myBaseClass
2000      #and they work as expected
3000       #This is the instance variable I wrote to and it worked.
               #The next three are from the instance variables I added to the subclass based on epics.Motor
None    #should have been 1000
None    #should have been 2000
None    #should have been 3000
--Matt Newville <newville at cars.uchicago.edu> 630-252-0431
RE: subclassing Pyepics epics.motor doesn't work as expected Terry Cornall
Prev: subclassing Pyepics epics.motor doesn't work as expected Terry Cornall
Next: Re: subclassing Pyepics epics.motor doesn't work as expected Vigder, Mark
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: subclassing Pyepics epics.motor doesn't work as expected Terry Cornall
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
