1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subclassing Pyepics epics.motor doesn't work as expected
Date: Thu, 29 May 2014 09:10:43 -0400
I found the best thing for PyEpics devices was to only have attributes that are associated with PV's. All other non-PV attributes are handled using explicit getters and setters, e.g., 'motor.getXxx()' instead of 'motor.xxx'. That way I don't have to worry about anybody treating a non-PV attribute as though it were a PV attribute, e.g., trying to add a callback on it.
On Wed, May 28, 2014 at 7:33 PM, Terry Cornall <[email protected]> wrote:
    Hi All.
    I’ve been trying to subclass the Motor class in Pyepics, so I can add my own variables and methods to it, and I’ve run into problems.
    Adding new methods seems to work just fine, but I find a strange problem when I try to add new ‘instance variables’ to my subclass.
    They all end up having value ‘None’ if I add them after doing the __init__ of the base Motor class. Worse, if I try to define
    them before I call the epics.Motor.__init__(), I get an exception from motor.py. This is not normal Python behaviour, as far as I know, and I’ve added code to test that I can subclass this way with a ‘simple’ python class, as shown below.
    Any ideas what I am doing wrong, or why epics.Motor can’t be subclassed in this way?
    Any suggestions as to how I can subclass it and add my own variables, or why I shouldn’t?
    I suppose an alternative would be to make a class that contains an epics.Motor object rather than subclass it.
    Terry
Prev: Re: subclassing Pyepics epics.motor doesn't work as expected Matt Newville
Next: caQtDM drag-and-drop workaround Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: subclassing Pyepics epics.motor doesn't work as expected Terry Cornall
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
