1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS database Feature request
To: "Jemian, Pete R." <[email protected]>, EPICS mailing list <[email protected]>
Date: Fri, 6 Jun 2014 09:49:47 -0700
Well, I forgot to specify it needs to work with 'macros' or rather IN template files
In other words, I want to use template files to overwrite other template files.
Something like
dbLoadTemplate('default_configuration')
dbLoadTemplate('patch_default_configuration')
or
dbLoadRecords(default_conf,macros)
dbLoadRecords(patch_conf,macros)
i.e. I do this for a lot of PVs and fields for each PV at once.
In some case, it is possible to use dbpfs (using epicsEnvSet and an postInit include of a file containing a series of dbpfs ), but it isn't as elegant and may turn out to be a management nightmare.  Bu I believe there are parameters that cannot be changed after the iocInit. So it is not a universal solution.
My goal is also to have this feature supported and be part of the epics-base.
The feature I am asking for is very close to what the alias directive is doing.
You can create PV aliases through db templates in 2 different ways:
1/
record(ao, "myAO") {
   alias( ...)                                      <-- I don't remember the exact syntax. I use 2nd method all the time
2/
alias("myAO", "myAlias")                <-- no need to know that myAO is an ao record.
FYI,
E
> Date: Fri, 6 Jun 2014 11:14:13 -0500
> From: [email protected]
> To: [email protected]
> Subject: Re: EPICS database Feature request
> On 6/6/2014 10:22 AM, Emmanuel Mayssat wrote:
> > changefield("myAO", VAL, 21)
> dbpf("myAO.VAL", 21)
> Pete R. Jemian, Ph.D. <[email protected]>
> Beam line Controls and Data Acquisition, Group Leader
> Advanced Photon Source, Argonne National Laboratory
> Argonne, IL 60439 630 - 252 - 3189
> Education is the one thing for which people
> are willing to pay yet not receive.
Re: EPICS database Feature request Andrew Johnson
EPICS database Feature request Emmanuel Mayssat
Re: EPICS database Feature request Pete Jemian
Prev: Re: Porting EPICS to a new OS Eric Norum
Next: Re: Porting EPICS to a new OS Stephen Beckwith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS database Feature request Pete Jemian
Next: Re: EPICS database Feature request Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
