1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS database Feature request
To: Emmanuel Mayssat <[email protected]>, EPICS mailing list <[email protected]>
Date: Fri, 6 Jun 2014 13:12:08 -0500
Hi Emmanuel,
On 06/06/2014 11:49 AM, Emmanuel Mayssat wrote:
> My goal is also to have this feature supported and be part of the
> epics-base.
> The feature I am asking for is very close to what the alias directive is
> doing.
Something like this could be added (in 3.15 or later, not 3.14 which is
now feature-frozen) quite easily. It would have to re-use the existing
syntax for setting field values though, say allowing a "*" meaning
"whatever" for the record type name when the record must already exist:
record("*", "myAO") {
   field(VAL, "21")
   field(FLNK, "AnotherAO.PROC")
That actually only requires a small change to the dbRecordHead() routine
in dbStaticLib to implement, the patch below adds that functionality to
Base-3.15:
=== modified file 'src/ioc/dbStatic/dbLexRoutines.c'
--- src/ioc/dbStatic/dbLexRoutines.c    2014-06-04 19:18:43 +0000
+++ src/ioc/dbStatic/dbLexRoutines.c    2014-06-06 18:01:38 +0000
@@ -931,6 +932,21 @@
     if (ellCount(&tempList))
         yyerrorAbort("dbRecordHead: tempList not empty");
     allocTemp(pdbentry);
+    if (recordType[0] == '*' && recordType[1] == 0) {
+        if (dbRecordsOnceOnly)
+            epicsPrintf("Record-type \"*\" not valid with
dbRecordsOnceOnly\n");
+        else {
+            status = dbFindRecord(pdbentry, name);
+            if (status == 0)
+                return; /* done */
+            epicsPrintf("Record \"%s\" not found\n", name);
+        yyerror(NULL);
+        duplicate = TRUE;
+        return;
     status = dbFindRecordType(pdbentry, recordType);
     if (status) {
         epicsPrintf("Record \"%s\" is of unknown type \"%s\"\n",
I'm not going to provide a patch against 3.14, but it wouldn't be hard
to add the same code there which ought to work...
I don't like the idea that this would silently ignore the new field
values if the named record does not exist though, that strikes me as
rather dangerous; is it essential for your situation? It triggers an
error in the above implementation:
tux% ./bin/linux-x86_64/softIoc -d ~/db/star.db
Record "nonexistent" not found
Error at or before ")" in file "/home/anj/db/star.db" line 11
If there are no complaints I will commit this change to the 3.15 branch.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: EPICS database Feature request Emmanuel Mayssat
Re: EPICS database Feature request Benjamin Franksen
Re: EPICS database Feature request Pete Jemian
Prev: Re: areaDetector acquirePeriod and acquireTime Zenon Szalata
Next: RE: EPICS database Feature request Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS database Feature request Emmanuel Mayssat
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
