On 14/06/2014 21:04, Vikram Bhagat
wrote:
From base folder
$ pwd
/opt/epics/base-3.14.12.4
and in
sncseq/configure/RELEASE
#EPICS_BASE=/home/phoebus/ANJ/epics/base/3-14-dev
EPICS_BASE=/opt/epics/base-3.14.12.4
what is wrong with this setting?
With Best Regards
Vikram
Vikram,
Which version of the sequencer are you trying to build?
The recent versions of the sequencer at [1] do not have such a
"/home/phoebus/..." line in .../configure/RELEASE that you show
commented out.
~Ralph
[1] http://www-csr.bessy.de/control/SoftDist/sequencer/index.html
It looks to
me like you have not correctly defined
EPICS_BASE in sncseq/configure/RELEASE.
Vikram Bhagat
[mailto:[email protected]]
Sent: Friday,
June 13, 2014 12:39 PM
To: Mark
Rivers; epics talk
Subject: Re:
sequencer installation
I
installed base3.14.12.4 but for
installation of sequencer, i have
below error
make[1]: Leaving directory
`/opt/epics/modules/sncseq/configure'
make -C ./src install
make[1]: Entering directory
`/opt/epics/modules/sncseq/src'
make -C ./pv install
make[2]: Entering directory
`/opt/epics/modules/sncseq/src/pv'
make -C O.linux-x86_64 -f ../Makefile
TOP=../../.. T_A=linux-x86_64
install
make[3]: Entering directory
`/opt/epics/modules/sncseq/src/pv/O.linux-x86_64'
make[3]: Nothing to be done for
`install'.
make[3]: Leaving directory
make[2]: Leaving directory
make -C ./seq install
`/opt/epics/modules/sncseq/src/seq'
install
`/opt/epics/modules/sncseq/src/seq/O.linux-x86_64'
make[3]: *** No rule to make target
`../../../lib/linux-x86_64/libiocsh.a',
needed by `libseq.a'. Stop.
make[2]: *** [install.linux-x86_64]
Error 2
make[1]: *** [seq.install] Error 2
make: *** [src.install] Error 2
Please suggest me how to come out from
this problem.
With best Regards
Vikram
I would suggest
using 3.14.12.4 and see if you
still have a problem.
Sent: Wednesday, June 04, 2014
3:14 PM
To: Mark Rivers; epics talk
Subject: Re: sequencer
installation
Dear Mark
There nothing special to use
EPICS3.15, i am installing in my
system so just took latest.
Vikram
On Wednesday, June 4, 2014 10:09
PM, Mark Rivers <[email protected]>
wrote:
You are using EPICS 3.15. Do you
have a reason for using that? It
is still not ready for production
systems. Should you be using
3.14.12.4 instead?
[[email protected]<mailto:[email protected]>]
on behalf of Vikram Bhagat [[email protected]<mailto:[email protected]>]
3:02 PM
To: epics talk
Subject: sequencer installation
Hello,
I am trying to install
sequencer but could not build
Below is the log an anyone guide
me what is wrong with
installation.
[root@sarva-PC<mailto:root@sarva-PC>
sncseq]# make
make -C ./configure install
../Makefile TOP=../..
T_A=linux-x86_64 install
`/opt/epics/modules/sncseq/configure/O.linux-x86_64'
perl -CSD
/opt/epics/base/bin/linux-x86_64/convertRelease.pl
checkRelease
../Makefile TOP=../../..
target
`/opt/epics/base-3.15.0.1/include/shareLib.h',
needed by `pvNew.o'. Stop.
make[2]: ***
[install.linux-x86_64] Error 2
make[1]: *** [pv.install] Error 2
sncseq]#
I set
in configure/RELEASE
Thanks
Vikram
- Re: sequencer installation Vikram Bhagat
- sequencer installation Vikram Bhagat
- RE: sequencer installation Mark Rivers
<2014>
2025
2026
<2014>
2025
2026
ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
