1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS alarming on VAL != X
To: Jameson Graef Rollins <[email protected]>, [email protected]
Date: Wed, 23 Jul 2014 10:52:54 -0500
On 7/21/14, 1:11 PM, Jameson Graef Rollins wrote:
> On Mon, Jul 21 2014, Benjamin Franksen
> <[email protected]> wrote:
>> Why don't you just set DRVL=DRVH=<the desired value>. In that case
>> the record simply can't take on any other value. No need to even
>> think about alarms for situations that can never arise...
> Hi, Ben.  For the moment we want to be able to easily change the
> parameters if needed; we just also want a good way to track any
> changes.  The alarm system would be a good way to do that, if we could
> alarm on records not being at a particular set point.
> We have also looked at "locking" the parameters to their set point
> values by using the access security framework, but we're hoping to
> avoid that level of restriction for the time being.  Access security
> would I think be preferable to something like DRVL=DRVH=VAL, since it
> would provide feedback to our MEDM operators that the parameters are
> purposely locked in place.
> Thanks for the suggestions, though.  Others are welcome!
Hi, Jamie.
It sounds like you're kind of abusing the EPICS alarm subsystem.  Maybe
a better approach would be to keep the expected values of PVs in a
separate system that just monitors or polls the PVs and alerts you via
email or whatever when a value is different from expected.  You then
either update the expected value in the separate system to match the new
value (legitimate change) or you track down why the value was changed
and revert it (illegitimate change).
Lewis
EPICS alarming on VAL != X Jameson Graef Rollins
Re: EPICS alarming on VAL != X Johnson, Andrew N.
Re: EPICS alarming on VAL != X Jameson Graef Rollins
Re: EPICS alarming on VAL != X Benjamin Franksen
Prev: Tabbed Container Ability Patard Charles-Henri
Next: Re: EPICS alarming on VAL != X Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS alarming on VAL != X Maren Purves
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
