1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on VxWorks6.9
To: Amit Chauhan <[email protected]>
Cc: "'Bhavna Merh'" <[email protected]>, "'Eric Norum'" <[email protected]>, [email protected]
Date: Wed, 30 Jul 2014 11:24:19 +0200
Amit,
From your original mail, I thought that it was the Windows build because I found the error directly after a call to 'cl', the Windows compiler that uses WIN32 include path and very much looks like a Windows build.
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\t
sDefs -IC
:\EPICS\base-3-14-12-4\\include\\os\\WIN32 -IC:\EPICS\base-3-14-12-4\\include        ..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp
..\..\..\src\libCom\ring\epicsRingPointer.h(93) : error C2664: 'delete' : cannot convert parameter 1 from 'void *volatile * ' to 'void *'
        Conversion loses qualifiers
        ..\..\..\src\libCom\ring\epicsRingPointer.cpp(82) : while compiling class-template member function '__thiscall epicsRingPointer<void>::~epicsRingPointer<void>(void)'
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
Do you call make with the -j option for parallel builds? In that case the output may be confusing and it can be hard to set error messages and commands into relation.
To make things clearer try first to build for the Windows host only and after that for vxWorks.
If compiling for Windows alone works it is probably a vxWorks compiler problem.
Concerning the error popup: This is probably a vxWorks cross tools thing, too. WindRiver is more and more annoying with each new version and calling the cross tools from make instead of their own environment is more and more complicated. I think this tool want to check if you have the proper vxWorks licenses installed. It seems you have to set a PATH to the lmapi.dll in a config file. I guess all previous attempts to compile vxWorks 6.9 have been made from Linux, not from Windows. So setups for Windows may be missing in the config files.
On 30.07.2014 09:08, Amit Chauhan wrote:
Dear Mark,
This is further to our trials of compiling EPICS for 'VxWorks 6.9'
We ran the 'make' from Visual Studio (2010) Command Prompt.
I am attaching following with this mail:
(1) CONFIG_SITE.Common.vxWorksCommon  : This is the only file we have
modified.
(2) make_output.txt : output of the make process (with error message
appended at the bottom )
(3) errMsg.jpg : This is a pop-up message we encountered 42 times  towards
the end of 'make' . We had to press 'OK' everytime to proceed.
During this trial no changes were made related to the ringPointer.
We would just like to add that when we are buidling EPICS base 3.14.12.4
with Visual Studio 2010 for 'Windows' as target, we are not encountering any
errors.
It is just that when we select 'vxWorks' as target the problems arise.
Amit Chauhan
RRCAT, Indore
EPICS on VxWorks6.9 Amit Chauhan
Re: EPICS on VxWorks6.9 Dirk Zimoch
RE: EPICS on VxWorks6.9 Mark Rivers
RE: EPICS on VxWorks6.9 Amit Chauhan
Prev: RE: EPICS on VxWorks6.9 Amit Chauhan
Next: RE: EPICS on VxWorks6.9 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
