1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS on VxWorks6.9
To: "'Mark Rivers'" <[email protected]>, "'Dirk Zimoch'" <[email protected]>, "'Eric Norum'" <[email protected]>
Cc: "'Bhavna Merh'" <[email protected]>, [email protected]
Date: Wed, 30 Jul 2014 12:38:35 +0530
Dear Mark,
This is further to our trials of compiling EPICS for 'VxWorks 6.9'
We ran the 'make' from Visual Studio (2010) Command Prompt.
I am attaching following with this mail:
(1) CONFIG_SITE.Common.vxWorksCommon  : This is the only file we have
modified.
(2) make_output.txt : output of the make process (with error message
appended at the bottom )
(3) errMsg.jpg : This is a pop-up message we encountered 42 times  towards
the end of 'make' . We had to press 'OK' everytime to proceed.
During this trial no changes were made related to the ringPointer.
We would just like to add that when we are buidling EPICS base 3.14.12.4
with Visual Studio 2010 for 'Windows' as target, we are not encountering any
errors.
It is just that when we select 'vxWorks' as target the problems arise.
Amit Chauhan
RRCAT, Indore
-----Original Message-----
Sent: Tuesday, July 29, 2014 8:05 AM
To: Amit Chauhan; 'Dirk Zimoch'; 'Eric Norum'
Cc: 'Bhavna Merh'
Hi Amit,
I have not heard back from you about this.
As I said, many people including me are building EPICS base 3.14.12.4 with
Visual Studio 2010 and are not seeing the errors you are seeing.  So there
must be something different about your configuration.
Sent: Tuesday, July 22, 2014 6:35 AM
Cc: [email protected]; 'Bhavna Merh'
Hi Amit,
I think the fact that you are building for vxWorks 6.9 is not relevant.  It
is failing when building for the host, which is win32-x86.  But you are
using Visual Studio 2010, which many of us are using without any problems.
Please do the following:
At the top level of base type:
make realclean realuninstall
Then type
make
and send the complete output when it fails.
Also please tell us what files you have modified in base/configure/os, and
how you have changed them.
Sent: Tuesday, July 22, 2014 12:46 AM
To: Mark Rivers; 'Dirk Zimoch'; 'Eric Norum'
Thanks to Mark and Dirk for taking their time out to dwell into the problem.
I am using Visual Studio 2010.
As suggested, I have NOT removed volatile keyword, but I have type casted
buffer as :
delete [ ] (T**) buffer;
As a result the make process has progressed beyond the point where it was
flagging error related to ringpointer.
But now the make process is stopping with following errors related to a file
named 'epicsSingleton.h' :
base-3-14-12-4\\include
..\\..\\..\\src\\libCom\\cxxTemplates\\epicsOnce.cpp
epicsOnce.cpp
..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(37) : error C2039:
'size_t' : is not a member of 'std'
..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(82) : error C2955:
'epicsSingleton' : use of class template requires template argument list
        ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(78) : see
declaration of 'epicsSingleton'
..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(87) : error C2244:
'epicsSingleton<TYPE>::reference::reference::reference' : unable to resolve
function overload
..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(89) : error C2954:
template definitions cannot nest
..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(57) : error C2027: use of
undefined type 'epicsSingleton<class epicsMutex>'
        ..\..\..\src\libCom\cxxTemplates\epicsOnce.cpp(40) : see reference
to class template instantiation 'epicsSingleton<class epicsMutex>' being
compiled
undefined type 'epicsSingleton<class tsFreeList<class epicsOnceImpl,16,class
epicsMutex> >'
        ..\..\..\src\libCom\cxxTemplates\epicsOnce.cpp(48) : see reference
to class template instantiation 'epicsSingleton<class tsFreeList<class
epicsOnceImpl,16,class epicsMutex> >' being compiled
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom'
make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src'
I am relatively new to EPICS and for the first time trying to build it for
VxWorks.
Suggestions to resolve these issues will be of help.
Amit Chauhan
RRCAT, Indore
Sent: Monday, July 21, 2014 5:56 PM
To: Dirk Zimoch; Eric Norum; [email protected]
> I just see that this is not a problem with vxWorks 6.9 but with the
> Windows host build.
> Eric, have you tested your change with Windows?
That change was done in EPICS base 3.14.10 in 2008.  We have certainly built
a lot on Windows since then!
The question is what version of Visual Studio is Amit using?  He did not
tell us that in the original post.  I have used Visual Studio 2008 and 2010
to compile base since 2008 and have not had this problem.  I suspect that
Amit is using a more recent version of Visual Studio?
Sent: Monday, July 21, 2014 3:15 AM
To: Mark Rivers; Eric Norum
Subject: Re: EPICS on VxWorks6.9
On 16.07.2014 20:40, Mark Rivers wrote:
>> The problem is
>>      T  * volatile * buffer;
>> in epicsRingPointer.h.
>> I am not sure if "volatile" really makes any sense here.I strongly
suggest NOT removing the volatile keyword.
> In October 2008 we struggled with a very nasty bug in epicsRingPointer.h.
The symptoms were:
> - Only failed on multi-processor systems
> - Only failed with recent versions of gcc with optimization enabled
> - Only failed 1 in 100,000 times
> Eric Norum fixed the problem.  The changes included the following
(comparison of epicsRingPointer.h from base 3.14.8.2 and 3.14.12.4)
> -private: // Data
> -    int nextPush;
> -    int nextPop;
> +private: /* Data */
> +    volatile int nextPush;
> +    volatile int nextPop;
>       int size;
> -    T **buffer;
> +    T  * volatile * buffer;
> So he added that volatile keyword, and it would need a lot of testing to
prove it is not needed.
> Mark
In that case the volatile needs to be removed for the delete, because it
seems that the compiler thinks that there is no delete operator for
arrays of volatiles and implicitly converting volatile away is
considered impossible.
Windows host build.
> From: [email protected] [mailto:[email protected]]
On Behalf Of Dirk Zimoch
> Sent: Wednesday, July 16, 2014 7:00 AM
> To: [email protected]
> Newer C++ compilers consider more and more things in EPICS errors. And
> maybe they are right.
> The problem is
> The other possibility is to cast away the "void" in the destructor.
> delete [ ] (T*) buffer;
> Or whatever the nicer C++ syntax is (probably using const_cast<T*>()?)
> Dirk
> On 16.07.2014 08:14, Amit Chauhan wrote:
>> Hi,
>> We are trying to put EPICS on VxWorks.
>> Various information related to our setup are:
>>            EPICS base version : 3.14.12.4
>>            VxWorks Version : 6.9
>> Workbench version : 3.3
>>            Host Architecture : win32 on x86
>>            Target Architecture: ppc-32
>>            Target Board :  MVME-5500 with PowerPC 7447 processor
>> On running the 'make' command, the EPICS build stops after a while with
>> an error.
>> *_Following is the output of the make command:_*
>> make -C ./configure install
>> make[1]: Entering directory `C:/EPICS/base-3-14-12-4/configure'
>> perl ../src/tools/makeMakefile.pl O.win32-x86 ../..
>> perl ../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../..
>> perl -MExtUtils::Command -e mkpath O.Common
>> make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
>> make[2]: Entering directory
`C:/EPICS/base-3-14-12-4/configure/O.win32-x86'
>> make[2]: Nothing to be done for `install'.
>> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. T_A=vxWorks-ppc32
install
>> `C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32'
>> make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/configure'
>> make -C ./src install
>> make[1]: Entering directory `C:/EPICS/base-3-14-12-4/src'
>> make -C ./tools install
>> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools'
>> perl ../../src/tools/makeMakefile.pl O.win32-x86 ../../..
>> perl ../../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../../..
>> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
>> make[3]: Entering directory
`C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86'
>> make[3]: Nothing to be done for `install'.
>> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32
>> install
>> `C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32'
>> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools'
>> make -C ./makeBaseApp install
>> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp'
>> perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl O.win32-x86
>> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86'
>> install
>> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32'
>> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp'
>> make -C ./makeBaseExt install
>> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt'
>> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86'
>> install
>> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32'
>> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt'
>> make -C ./libCom install
>> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom'
>> perl ../../../src/libCom/misc/makeEpicsVersion.pl
>> ../../../configure/CONFIG_BASE_VERSION ../O.Common
>> Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
>> Found EPICS Version 3.14.12.4
>> "Installing generated generic include file
>> C:\EPICS\base-3-14-12-4/include/epicsVersion.h"
>> rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32
>> -I../../../src/libCom/osi/os/default -I..
>> -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
>> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
>> -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
>> -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
>> -I../../../src/libCom/env -I../../../src/libCom/error
>> -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
>> -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
>> -I../../../src/libCom/logClient -I../../../src/libCom/macLib
>> -I../../../src/libCom/misc -I../../../src/libCom/osi
>> -I../../../src/libCom/taskwd -I../../../src/libCom/timer
>> -I../../../src/libCom/tsDefs -IC:\EPICS\base-3-14-12-4/include/os/WIN32
>> -IC:\EPICS\base-3-14-12-4/include -fo Com.res ../Com.rc
>> cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
>> /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT
>> -DEPICS_DLL_NO -I. -I..\\O.Common -I.
>> -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32
>> -I..\\..\\..\\src\\libCom\\osi\\os\\default -I..
>> -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring
>> -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast
>> -I..\\..\\..\\src\\libCom\\cppStd
>> -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf
>> -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env
>> -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr
>> -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash
>> -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient
>> -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc
>> -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd
>> -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs
>> -IC:\EPICS\base-3-14-12-4\\include\\os\\WIN32
>> ..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c
>> bucketLib.c
>> cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
>> -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I.
>> ..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp
>> ..\..\..\src\libCom\ring\epicsRingPointer.h(93) : *error C2664: 'delete'
>> : cannot convert parameter 1 from 'void *volatile * ' to 'void *'*
>> *        Conversion loses qualifiers*
>> ..\..\..\src\libCom\ring\epicsRingPointer.cpp(82) : while compiling
>> class-template member function '__thiscall
>> epicsRingPointer<void>::~epicsRingPointer<void>(void)'
>> */The following code is written in epicsRingPointer.h (line 93):/*
>> inline epicsRingPointer<T>:: ~epicsRingPointer( )
>> { delete [ ] buffer; }
>> If anyone can suggest us the solution to overcome this error it will be
>> of help to us.
>> Regards,
>> Amit Chauhan,
>> RRCAT, Indore
Attachment: CONFIG_SITE.Common.vxWorksCommon
Description: Binary data
Attachment: errMsg.JPG
Description: JPEG image
make[2]: Entering directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86'
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. T_A=vxWorks-ppc32 install
make[2]: Entering directory `C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32'
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86'
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing script ../../../bin/win32-x86/convertRelease.pl"
mkdir ../../../bin
mkdir ../../../bin/win32-x86
"Installing script ../../../bin/win32-x86/cvsclean.pl"
"Installing script ../../../bin/win32-x86/dos2unix.pl"
"Installing script ../../../bin/win32-x86/expandVars.pl"
"Installing script ../../../bin/win32-x86/filterWarnings.pl"
"Installing script ../../../bin/win32-x86/fullPathName.pl"
"Installing script ../../../bin/win32-x86/installEpics.pl"
"Installing script ../../../bin/win32-x86/makeIncludeDbd.pl"
"Installing script ../../../bin/win32-x86/makeMakefile.pl"
"Installing script ../../../bin/win32-x86/makeTestfile.pl"
"Installing script ../../../bin/win32-x86/mkmf.pl"
"Installing script ../../../bin/win32-x86/munch.pl"
"Installing script ../../../bin/win32-x86/replaceVAR.pl"
"Installing script ../../../bin/win32-x86/useManifestTool.pl"
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86'
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32 install
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32'
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32'
perl ../../bin/win32-x86/makeMakefile.pl O.win32-x86 ../../..
perl ../../bin/win32-x86/makeMakefile.pl O.vxWorks-ppc32 ../../..
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86'
"Installing script ../../../bin/win32-x86/makeBaseApp.pl"
"Installing ../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../templates
mkdir ../../../templates/makeBaseApp
mkdir ../../../templates/makeBaseApp/top
"Installing ../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../templates/makeBaseApp/top/configure
"Installing ../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../templates/makeBaseApp/top/configure/RULES_TOP"
"Installing ../../../templates/makeBaseApp/top/supportApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp
"Installing ../../../templates/makeBaseApp/top/supportApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp/Db
"Installing ../../../templates/makeBaseApp/top/supportApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/supportApp/src
"Installing ../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd"
"Installing ../../../templates/makeBaseApp/top/iocApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp
"Installing ../../../templates/makeBaseApp/top/iocApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp/Db
"Installing ../../../templates/makeBaseApp/top/iocApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocApp/src
"Installing ../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp/Db
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions"
"Installing ../../../templates/makeBaseApp/top/exampleApp/Db/userHost.substitutions"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleApp/src
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c"
"Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/Makefile"
mkdir ../../../templates/makeBaseApp/top/exampleBoot
"Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common"
mkdir ../../../templates/makeBaseApp/top/exampleBoot/ioc
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common"
"Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks"
"Installing ../../../templates/makeBaseApp/top/caClientApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/caClientApp
"Installing ../../../templates/makeBaseApp/top/caClientApp/caExample.c"
"Installing ../../../templates/makeBaseApp/top/caClientApp/caMonitor.c"
"Installing ../../../templates/makeBaseApp/top/caServerApp/Makefile"
mkdir ../../../templates/makeBaseApp/top/caServerApp
"Installing ../../../templates/makeBaseApp/top/caServerApp/README"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.h"
"Installing ../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/main.cc"
"Installing ../../../templates/makeBaseApp/top/caServerApp/test.adl"
"Installing ../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc"
"Installing ../../../templates/makeBaseApp/top/iocBoot/Makefile"
mkdir ../../../templates/makeBaseApp/top/iocBoot
"Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks"
"Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common"
mkdir ../../../templates/makeBaseApp/top/iocBoot/ioc
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks"
"Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS"
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86'
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32'
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32'
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86'
"Installing script ../../../bin/win32-x86/makeBaseExt.pl"
"Installing ../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../templates/makeBaseExt
mkdir ../../../templates/makeBaseExt/top
"Installing ../../../templates/makeBaseExt/top/README"
"Installing ../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../templates/makeBaseExt/top/configure
"Installing ../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_PYTHON"
"Installing ../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386"
mkdir ../../../templates/makeBaseExt/top/configure/os
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland.win32-x86-borland"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.hpux-parisc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.interix-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-borland.linux-x86-borland"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-borland.win32-x86-borland"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86"
"Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64"
"Installing ../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../templates/makeBaseExt/top/src
"Installing ../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing ../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../templates/makeBaseExt/top/simpleExt/Makefile"
mkdir ../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86'
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32'
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32'
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
perl ../../../src/libCom/misc/makeEpicsVersion.pl ../../../configure/CONFIG_BASE_VERSION ../O.Common
"Installing generated generic include file ../../../include/epicsVersion.h"
mkdir ../../../include
"Installing generic include file ../../../include/bucketLib.h"
"Installing generic include file ../../../include/epicsRingPointer.h"
"Installing generic include file ../../../include/epicsRingBytes.h"
"Installing generic include file ../../../include/postfix.h"
"Installing generic include file ../../../include/cvtFast.h"
"Installing generic include file ../../../include/epicsAlgorithm.h"
"Installing generic include file ../../../include/epicsExcept.h"
"Installing generic include file ../../../include/epicsMemory.h"
"Installing generic include file ../../../include/resourceLib.h"
"Installing generic include file ../../../include/tsDLList.h"
"Installing generic include file ../../../include/tsSLList.h"
"Installing generic include file ../../../include/tsMinMax.h"
"Installing generic include file ../../../include/tsBTree.h"
"Installing generic include file ../../../include/tsFreeList.h"
"Installing generic include file ../../../include/epicsSingleton.h"
"Installing generic include file ../../../include/epicsGuard.h"
"Installing generic include file ../../../include/epicsOnce.h"
"Installing generic include file ../../../include/dbmf.h"
"Installing generic include file ../../../include/ellLib.h"
"Installing generic include file ../../../include/envDefs.h"
"Installing generic include file ../../../include/epicsPrint.h"
"Installing generic include file ../../../include/errMdef.h"
"Installing generic include file ../../../include/errSymTbl.h"
"Installing generic include file ../../../include/errlog.h"
"Installing generic include file ../../../include/error.h"
"Installing generic include file ../../../include/fdManager.h"
"Installing generic include file ../../../include/fdmgr.h"
"Installing generic include file ../../../include/freeList.h"
"Installing generic include file ../../../include/gpHash.h"
"Installing generic include file ../../../include/iocsh.h"
"Installing generic include file ../../../include/registry.h"
"Installing generic include file ../../../include/libComRegister.h"
"Installing generic include file ../../../include/iocLog.h"
"Installing generic include file ../../../include/logClient.h"
"Installing generic include file ../../../include/macLib.h"
"Installing generic include file ../../../include/adjustment.h"
"Installing generic include file ../../../include/cantProceed.h"
"Installing generic include file ../../../include/dbDefs.h"
"Installing generic include file ../../../include/epicsConvert.h"
"Installing generic include file ../../../include/epicsExit.h"
"Installing generic include file ../../../include/epicsStdlib.h"
"Installing generic include file ../../../include/epicsString.h"
"Installing generic include file ../../../include/epicsTypes.h"
"Installing generic include file ../../../include/shareLib.h"
"Installing generic include file ../../../include/epicsExport.h"
"Installing generic include file ../../../include/unixFileName.h"
"Installing generic include file ../../../include/locationException.h"
"Installing generic include file ../../../include/ipAddrToAsciiAsynchronous.h"
"Installing generic include file ../../../include/compilerDependencies.h"
"Installing generic include file ../../../include/epicsUnitTest.h"
"Installing generic include file ../../../include/testMain.h"
"Installing generic include file ../../../include/os/WIN32/osiFileName.h"
mkdir ../../../include/os
mkdir ../../../include/os/WIN32
"Installing generic include file ../../../include/osiSock.h"
"Installing generic include file ../../../include/os/WIN32/osdSock.h"
"Installing generic include file ../../../include/epicsInterrupt.h"
"Installing os dependent include file ../../../include/os/WIN32/osdInterrupt.h"
"Installing generic include file ../../../include/epicsMutex.h"
"Installing generic include file ../../../include/os/WIN32/osdMutex.h"
"Installing generic include file ../../../include/epicsEvent.h"
"Installing generic include file ../../../include/os/WIN32/osdEvent.h"
"Installing generic include file ../../../include/os/WIN32/epicsMath.h"
"Installing os dependent include file ../../../include/os/WIN32/osdMessageQueue.h"
"Installing generic include file ../../../include/os/WIN32/osdStrtod.h"
"Installing generic include file ../../../include/epicsAssert.h"
"Installing generic include file ../../../include/epicsFindSymbol.h"
"Installing generic include file ../../../include/osiPoolStatus.h"
"Installing generic include file ../../../include/os/WIN32/osdPoolStatus.h"
"Installing generic include file ../../../include/os/WIN32/osdThread.h"
"Installing generic include file ../../../include/epicsThread.h"
"Installing generic include file ../../../include/epicsTime.h"
"Installing generic include file ../../../include/epicsGeneralTime.h"
"Installing generic include file ../../../include/os/WIN32/osdTime.h"
"Installing generic include file ../../../include/generalTimeSup.h"
"Installing generic include file ../../../include/osiClockTime.h"
"Installing generic include file ../../../include/epicsSignal.h"
"Installing generic include file ../../../include/osiProcess.h"
"Installing generic include file ../../../include/os/WIN32/osiUnistd.h"
"Installing generic include file ../../../include/osiWireFormat.h"
"Installing os dependent include file ../../../include/os/WIN32/osdWireFormat.h"
"Installing generic include file ../../../include/os/WIN32/osdWireConfig.h"
"Installing generic include file ../../../include/epicsEndian.h"
"Installing os dependent include file ../../../include/os/WIN32/epicsReadline.h"
"Installing generic include file ../../../include/epicsMessageQueue.h"
"Installing generic include file ../../../include/epicsStdio.h"
"Installing generic include file ../../../include/epicsStdioRedirect.h"
"Installing generic include file ../../../include/os/WIN32/epicsGetopt.h"
"Installing generic include file ../../../include/devLib.h"
"Installing generic include file ../../../include/devLibVME.h"
"Installing generic include file ../../../include/devLibVMEImpl.h"
"Installing os dependent include file ../../../include/os/WIN32/osdVME.h"
"Installing generic include file ../../../include/taskwd.h"
"Installing generic include file ../../../include/epicsTimer.h"
"Installing generic include file ../../../include/tsDefs.h"
rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include        -fo Com.res ../Com.rc
Microsoft (R) Windows (R) Resource Compiler Version 6.1.7600.16385Copyright (C) Microsoft Corporation.  All rights reserved.
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c
bucketLib.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\ring\\epicsRingBytes.c
epicsRingBytes.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\calc\\postfix.c
postfix.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\calc\\calcPerform.c
calcPerform.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\cvtFast\\cvtFast.c
cvtFast.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\cxxTemplates\\resourceLib.cpp
resourceLib.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\cxxTemplates\\epicsOnce.cpp
epicsOnce.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\cxxTemplates\\epicsSingletonMutex.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\dbmf\\dbmf.c
dbmf.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\ellLib\\ellLib.c
ellLib.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\env\\envSubr.c
envSubr.c
perl ../../../src/libCom/env/bldEnvData.pl ../../../configure
Generating envData.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        envData.c
envData.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\error\\errlog.c
errlog.c
..\..\..\src\libCom\error\errlog.c(97) : warning C4018: '>=' : signed/unsigned mismatch
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\error\\errSymLib.c
errSymLib.c
perl ../../../src/libCom/error/makeStatTbl.pl  ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        errSymTbl.c
errSymTbl.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\fdmgr\\fdmgr.cpp
fdmgr.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\fdmgr\\fdManager.cpp
fdManager.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\freeList\\freeListLib.c
freeListLib.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\gpHash\\gpHashLib.c
gpHashLib.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\iocsh\\iocsh.cpp
iocsh.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\iocsh\\registry.c
registry.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\iocsh\\libComRegister.c
libComRegister.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\logClient\\iocLog.c
iocLog.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\logClient\\logClient.c
logClient.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\macLib\\macCore.c
macCore.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\macLib\\macEnv.c
macEnv.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\macLib\\macUtil.c
macUtil.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\aToIPAddr.c
aToIPAddr.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\adjustment.c
adjustment.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\cantProceed.c
cantProceed.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\epicsConvert.c
epicsConvert.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\epicsExit.c
epicsExit.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\epicsStdlib.c
epicsStdlib.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\epicsString.c
epicsString.c
..\..\..\src\libCom\misc\epicsString.c(46) : warning C4018: '<' : signed/unsigned mismatch
..\..\..\src\libCom\misc\epicsString.c(49) : warning C4018: '>=' : signed/unsigned mismatch
..\..\..\src\libCom\misc\epicsString.c(138) : warning C4018: '<' : signed/unsigned mismatch
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\truncateFile.c
truncateFile.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\ipAddrToAsciiAsynchronous.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\misc\\epicsUnitTest.c
epicsUnitTest.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\epicsThread.cpp
epicsThread.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\epicsMutex.cpp
epicsMutex.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\epicsEvent.cpp
epicsEvent.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\epicsTime.cpp
epicsTime.cpp
..\..\..\src\libCom\osi\epicsTime.cpp(340) : warning C4244: '=' : conversion from 'time_t' to 'long', possible loss of data
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\epicsMessageQueue.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\epicsMath.cpp
epicsMath.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\epicsGeneralTime.c
epicsGeneralTime.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\osiClockTime.c
osiClockTime.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdSock.c
osdSock.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdSockAddrReuse.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\osiSock.c
osiSock.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\systemCallIntMech.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\epicsSocketConvertErrnoToString.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\default\\osdAssert.c
osdAssert.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdFindSymbol.c
osdFindSymbol.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\default\\osdInterrupt.c
osdInterrupt.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdPoolStatus.c
osdPoolStatus.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdSignal.cpp
osdSignal.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\default\\osdEnv.c
osdEnv.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS    /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\default\\epicsReadline.c
epicsReadline.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\epicsTempFile.cpp
epicsTempFile.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\epicsStdio.c
epicsStdio.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdStdio.c
osdStdio.c
cl -c          -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING     /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdThread.c
osdThread.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdMutex.c
osdMutex.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdEvent.c
osdEvent.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdTime.cpp
osdTime.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdProcess.c
osdProcess.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdNetIntf.c
osdNetIntf.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\default\\osdMessageQueue.cpp
osdMessageQueue.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\devLibVME.c
devLibVME.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\default\\devLibVMEOSD.c
devLibVMEOSD.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\taskwd\\taskwd.c
taskwd.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\timer\\epicsTimer.cpp
epicsTimer.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\timer\\timer.cpp
timer.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\timer\\timerQueue.cpp
timerQueue.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\timer\\timerQueueActive.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\timer\\timerQueueActiveMgr.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\timer\\timerQueuePassive.cpp
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\tsDefs\\tsDefs.c
tsDefs.c
cl -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\epicsGetopt.c
epicsGetopt.c
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\setThreadName.cpp
setThreadName.cpp
cl /nologo /EHsc /GR -c               /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include        ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\forceBadAllocException.cpp
lib /nologo /verbose /out:Com.lib /LTCG        bucketLib.obj epicsRingPointer.obj epicsRingBytes.obj postfix.obj calcPerform.obj cvtFast.obj resourceLib.obj epicsOnce.obj epicsSingletonMutex.obj dbmf.obj ellLib.obj envSubr.obj envData.obj errlog.obj errSymLib.obj errSymTbl.obj fdmgr.obj fdManager.obj freeListLib.obj gpHashLib.obj iocsh.obj registry.obj libComRegister.obj iocLog.obj logClient.obj macCore.obj macEnv.obj macUtil.obj aToIPAddr.obj adjustment.obj cantProceed.obj epicsConvert.obj epicsExit.obj epicsStdlib.obj epicsString.obj truncateFile.obj ipAddrToAsciiAsynchronous.obj epicsUnitTest.obj epicsThread.obj epicsMutex.obj epicsEvent.obj epicsTime.obj epicsMessageQueue.obj epicsMath.obj epicsGeneralTime.obj osiClockTime.obj osdSock.obj osdSockAddrReuse.obj osiSock.obj systemCallIntMech.obj epicsSocketConvertErrnoToString.obj osdAssert.obj osdFindSymbol.obj osdInterrupt.obj osdPoolStatus.obj osdSignal.obj osdEnv.obj epicsReadline.obj epicsTempFile.obj epicsStdio.obj osdStdio.obj osdThread.obj osdMutex.obj osdEvent.obj osdTime.obj osdProcess.obj osdNetIntf.obj osdMessageQueue.obj devLibVME.obj devLibVMEOSD.obj taskwd.obj epicsTimer.obj timer.obj timerQueue.obj timerQueueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj tsDefs.obj epicsGetopt.obj setThreadName.obj forceBadAllocException.obj
Appending forceBadAllocException.obj
Appending setThreadName.obj
Appending epicsGetopt.obj
Appending tsDefs.obj
Appending timerQueuePassive.obj
Appending timerQueueActiveMgr.obj
Appending timerQueueActive.obj
Appending timerQueue.obj
Appending timer.obj
Appending epicsTimer.obj
Appending taskwd.obj
Appending devLibVMEOSD.obj
Appending devLibVME.obj
Appending osdMessageQueue.obj
Appending osdNetIntf.obj
Appending osdProcess.obj
Appending osdTime.obj
Appending osdEvent.obj
Appending osdMutex.obj
Appending osdThread.obj
Appending osdStdio.obj
Appending epicsStdio.obj
Appending epicsTempFile.obj
Appending epicsReadline.obj
Appending osdEnv.obj
Appending osdSignal.obj
Appending osdPoolStatus.obj
Appending osdInterrupt.obj
Appending osdFindSymbol.obj
Appending osdAssert.obj
Appending epicsSocketConvertErrnoToString.obj
Appending systemCallIntMech.obj
Appending osiSock.obj
Appending osdSockAddrReuse.obj
Appending osdSock.obj
Appending osiClockTime.obj
Appending epicsGeneralTime.obj
Appending epicsMath.obj
Appending epicsMessageQueue.obj
Appending epicsTime.obj
Appending epicsEvent.obj
Appending epicsMutex.obj
Appending epicsThread.obj
Appending epicsUnitTest.obj
Appending ipAddrToAsciiAsynchronous.obj
Appending truncateFile.obj
Appending epicsString.obj
Appending epicsStdlib.obj
Appending epicsExit.obj
Appending epicsConvert.obj
Appending cantProceed.obj
Appending adjustment.obj
Appending aToIPAddr.obj
Appending macUtil.obj
Appending macEnv.obj
Appending macCore.obj
Appending logClient.obj
Appending iocLog.obj
Appending libComRegister.obj
Appending registry.obj
Appending iocsh.obj
Appending gpHashLib.obj
Appending freeListLib.obj
Appending fdManager.obj
Appending fdmgr.obj
Appending errSymTbl.obj
Appending errSymLib.obj
Appending errlog.obj
Appending envData.obj
Appending envSubr.obj
Appending ellLib.obj
Appending dbmf.obj
Appending epicsSingletonMutex.obj
Appending epicsOnce.obj
Appending resourceLib.obj
Appending cvtFast.obj
Appending calcPerform.obj
Appending postfix.obj
Appending epicsRingBytes.obj
Appending epicsRingPointer.obj
Appending bucketLib.obj
"Installing library ../../../lib/win32-x86/Com.lib"
mkdir ../../../lib/win32-x86
"Installing html ../../../html//freeList/freeList.html"
mkdir ../../../html
mkdir ../../../html/freeList
"Installing html ../../../html//gpHash/gpHash.html"
mkdir ../../../html/gpHash
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32 install
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom/O.vxWorks-ppc32'
"Installing generic include file ../../../include/os/vxWorks/osiFileName.h"
mkdir ../../../include/os/vxWorks
"Installing generic include file ../../../include/os/vxWorks/osdSock.h"
"Installing generic include file ../../../include/os/vxWorks/osdInterrupt.h"
"Installing generic include file ../../../include/os/vxWorks/osdMutex.h"
"Installing generic include file ../../../include/os/vxWorks/osdEvent.h"
"Installing generic include file ../../../include/os/vxWorks/epicsMath.h"
"Installing generic include file ../../../include/os/vxWorks/osdMessageQueue.h"
"Installing generic include file ../../../include/os/vxWorks/osdStrtod.h"
"Installing os dependent include file ../../../include/os/vxWorks/osdPoolStatus.h"
"Installing generic include file ../../../include/os/vxWorks/osdThread.h"
"Installing generic include file ../../../include/os/vxWorks/osdTime.h"
"Installing os dependent include file ../../../include/os/vxWorks/osiUnistd.h"
"Installing os dependent include file ../../../include/os/vxWorks/osdWireFormat.h"
"Installing generic include file ../../../include/os/vxWorks/osdWireConfig.h"
"Installing os dependent include file ../../../include/os/vxWorks/epicsReadline.h"
"Installing os dependent include file ../../../include/os/vxWorks/epicsGetopt.h"
"Installing generic include file ../../../include/os/vxWorks/osdVME.h"
"Installing generic include file ../../../include/os/vxWorks/camacLib.h"
"Installing generic include file ../../../include/os/vxWorks/epicsDynLink.h"
"Installing generic include file ../../../include/os/vxWorks/module_types.h"
"Installing generic include file ../../../include/os/vxWorks/task_params.h"
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/osi/os/vxWorks/vxComLibrary.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/bucketLib/bucketLib.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/ring/epicsRingPointer.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/ring/epicsRingBytes.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/calc/postfix.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/calc/calcPerform.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/cvtFast/cvtFast.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/cxxTemplates/resourceLib.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/cxxTemplates/epicsOnce.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/dbmf/dbmf.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/ellLib/ellLib.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/env/envSubr.c
perl ../../../src/libCom/env/bldEnvData.pl ../../../configure
Generating envData.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip envData.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/error/errlog.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/error/errSymLib.c
perl ../../../src/libCom/error/makeStatTbl.pl  ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip errSymTbl.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/fdmgr/fdmgr.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/fdmgr/fdManager.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/freeList/freeListLib.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/gpHash/gpHashLib.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/iocsh/iocsh.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/iocsh/registry.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/iocsh/libComRegister.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/logClient/iocLog.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/logClient/logClient.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/macLib/macCore.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/macLib/macEnv.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/macLib/macUtil.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/aToIPAddr.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/adjustment.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/cantProceed.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsConvert.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsExit.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsStdlib.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsString.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/truncateFile.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsUnitTest.c
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/osi/epicsThread.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/osi/epicsMutex.cpp
C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c            -DCPU=PPC32  -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall     -mstrict-align -mlongcall    -fno-builtin  -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include       -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/osi/epicsEvent.cpp
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.vxWorks-ppc32'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom'
make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src'
*********** Error messages received on the command prompt ***************
C:\EPICS\base-3-14-12-4>make >make_output.txt
In file included from ../../../src/libCom/osi/epicsStdio.h:15,
                 from ../../../src/libCom/osi/epicsStdioRedirect.h:19,
                 from ../../../src/libCom/osi/epicsEvent.cpp:19:
C:/WindRiver/vxworks-6.9/target/h/stdio.h:318: error: declaration of C function
'int oprintf(int (*)(...), _Vx_usr_arg_t, const char*, ...)' conflicts with
C:/WindRiver/vxworks-6.9/target/h/stdio.h:206: error: previous declaration 'int
oprintf(int (*)(char*, size_t, _Vx_usr_arg_t), _Vx_usr_arg_t, const char*, ...)'
 here
C:/WindRiver/vxworks-6.9/target/h/stdio.h:337: error: declaration of C function
'int voprintf(int (*)(...), _Vx_usr_arg_t, const char*, __va_list_tag*)' conflic
ts with
C:/WindRiver/vxworks-6.9/target/h/stdio.h:225: error: previous declaration 'int
voprintf(int (*)(char*, size_t, _Vx_usr_arg_t), _Vx_usr_arg_t, const char*, __va
_list_tag*)' here
C:/WindRiver/vxworks-6.9/target/h/stdio.h: In function 'int voprintf(int (*)(...
), _Vx_usr_arg_t, const char*, __va_list_tag*)':
C:/WindRiver/vxworks-6.9/target/h/stdio.h:348: error: invalid conversion from 'i
nt (*)(char*, size_t, _Vx_usr_arg_t)' to 'int (*)(...)'
C:/WindRiver/vxworks-6.9/target/h/stdio.h:348: error:   initializing argument 1
of 'int voprintf(int (*)(...), _Vx_usr_arg_t, const char*, __va_list_tag*)'
make[3]: *** [epicsEvent.o] Error 1
make[2]: *** [install.vxWorks-ppc32] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
Re: EPICS on VxWorks6.9 Dirk Zimoch
RE: EPICS on VxWorks6.9 Mark Rivers
EPICS on VxWorks6.9 Amit Chauhan
RE: EPICS on VxWorks6.9 Amit Chauhan
Prev: Power PMAC and EPICS Time stamps Choon Lim
Next: Re: EPICS on VxWorks6.9 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS on VxWorks6.9 Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
