1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: about caPutLog
To: Zhao Zhuo <[email protected]>
Cc: [email protected]
Date: Tue, 2 Sep 2014 11:24:33 +0200
I am forwarding this issue to tech-talk. Maybe someone there has an idea? The
attached picture shows the messages from the IOC.
Am Dienstag, 2. September 2014, 12:35:08 schrieben Sie:
> Hi, Ben,
>        Thank you for your reply.
>        It seems it's not related to "firewall". I've disabled the firewall,
> but the error still exsited.
> I even enabled the firewall and open the port 7011 as "/sbin/iptables -I
> INPUT -p tcp --dport 7011 -j ACCEPT", it still didn't work.
>        My soft IOC server and client is on the same Linux/PC, is it OK?
> zhaozhuo
> -----原始邮件-----
> From: Benjamin Franksen
> Sent: Monday, September 01, 2014 2:55 PM
> To: Zhao Zhuo
> On Friday 29 August 2014 17:12:48 you wrote:
> > Hi, Ben Franksen,
> > I’m trying to run CaPutLog on my RedHat Linux PC, but it showed the
> > following error when I run the "st.cmd”. Do you know what’s wrong
> > with it?
> The log client on the IOC cannot connect to the log server. The error
> message clearly says why: "Connection refused". This is a question of
> your system's setup. One reason could be that you have a firewall
> running on your machine ("localhost"). Try configuring it to allow the
> caPutLog port (7011 by default).
> Cheers
> Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Attachment: image[1].png
Description: PNG image
Re: about caPutLog Ralph Lange
Prev: Re: Making two computers communicate. Vlad Andrei Rusu
Next: Re: about caPutLog Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: stream device get started? Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
