1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: stream device get started?
To: "'Alireza Panna'" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 2 Sep 2014 15:49:31 +0000
I apologize, I didn’t read carefully that you were running the makeSupport.pl to create the application.  I get the same error as you when I try to run that script on Windows, it seems that the Perl script does not understand Windows path syntax.
You can run the script on Linux and then just copy the tree to your Windows machine until we get that fixed.
Sent: Tuesday, September 02, 2014 10:32 AM
To: Mark Rivers
Cc: Ralph Lange; EPICS Tech-Talk
Subject: Re: stream device get started?
Hello all,
Yes, it is true that EPICS_HOST_ARCH should be set in the environment which I do. Now correct me If I am wrong, but I was under the impression that the makeSupport perl script in ../aysn-4-23/bin/<arch>/ creates the device support directories i.e the configure/release files and so on and then you run makeBase.pl to create the application.  This is where my problem is, because when I run makeSupport.pl, I get the error mentioned in the first email. I might be wrong since I am fairly new to the EPICS community.
Thank you
Ali
Alireza Panna
University of Maryland, College Park
On Tue, Sep 2, 2014 at 7:15 AM, Mark Rivers <[email protected]> wrote:
Ralph is right, only ASYN should be defined in configure/RELEASE, EPICS_HOST_ARCH should be defined as an environment variable.
From: [email protected] [[email protected]] on behalf of Ralph Lange [[email protected]]
Sent: Tuesday, September 02, 2014 2:35 AM
To: EPICS Tech-Talk
Cc: Alireza Panna
On 01/09/2014 21:00, Mark Rivers wrote:
>> EPICS_HOST_ARCH  env var is set and so is ASYN.
> These should not be set as environment variables, they should be defined in the configure/RELEASE file of your application.
Well...
While definitions of external modules like ASYN should always go into
the configure/RELEASE file (it is named RELEASE because it defines the
exact releases of external modules that you are using), EPICS_HOST_ARCH
is meant to be set in the environment.
While setting it in configure/RELEASE might work, the host architecture
is rather a property of the host than a definition of an external module.
As soon as you put your sources on a network drive and compile it for
multiple host architectures inside the same structure, setting the host
architecture in configure/RELEASE is obviously not a good idea.
~Ralph
stream device get started? Alireza Panna
RE: stream device get started? Mark Rivers
Re: stream device get started? Ralph Lange
Re: stream device get started? Alireza Panna
Prev: Re: stream device get started? Alireza Panna
Next: Re: motorApp R6.8 Mclennan PM600 opposite limit datum search mode on linux-arm Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: about caPutLog Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
