On 09/03/2014 10:21 AM, Pearson, Matthew R. wrote:
> You can also set the TPRO field to 1 in that record, which will cause
> a string to be printed on the IOC shell whenever that record is
> processed (although it might just do it at the SCAN rate, and not
> reflect any ongoing processing. Not sure).
If a record with TPRO set is already active (PACT set) when it is asked
to process the message printed will say "Active"; if processing is
disabled with the SDIS/DISA/DISV mechanism the message will say
"Disabled". The normal "Process" message is printed immediately before
the record's process() routine is called.
Note that setting TPRO on one record also triggers messages from any
down-stream records that get processed synchronously through DB links
from that record — the downstream records must be in the same lock-set,
and get processed before the process() routine from the TPRO record has
returned.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Processing a record a in loop David Michel
- RE: Processing a record a in loop Mark Rivers
- Re: Processing a record a in loop David Michel
- Re: Processing a record a in loop Pearson, Matthew R.
RE: synApps_5_7 build error on Windows 8.1 x64 freddie.akeroyd
<2014>
2025
2026
Re: Processing a record a in loop Eric Norum
<2014>
2025
2026
