1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is RULES_JAVA broken?
To: Nerses Gevorgyan <[email protected]>, [email protected]
Date: Tue, 16 Sep 2014 09:50:44 -0500
On 9/15/14, 11:00 PM, Nerses Gevorgyan wrote:
> The Makefile is quite simple.
> vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
> TOP=../..
> JAVA_DIR = ~rafopar/Apps/Java/jdk1.7.0_67
Hi, Nerses.
I've never used RULES_JAVA, so I'm not commenting on any of your
reported problems, except I will say that your use of a tilde character
('~') in your JAVA_DIR path might be a problem.  That is normally a
special syntax recognized by certain shells that will be expanded to a
user's home directory.  That might not work as you're expecting in GNU
Make.  I suggest replacing that with an absolute path.
Lewis
Re: Is RULES_JAVA broken? Nerses Gevorgyan
Re: Is RULES_JAVA broken? Benjamin Franksen
Prev: Asyn model 3 driver for Galil products Mark Clift
Next: Re: Question about asyn and offline device Sonya Hoobler
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Is RULES_JAVA broken? Nerses Gevorgyan
Next: Re: Is RULES_JAVA broken? Nerses Gevorgyan
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
