1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is RULES_JAVA broken?
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Tue, 16 Sep 2014 13:58:13 -0400 (EDT)
Thanks Lewis,
I replaced the tilde chararcter. Nothing changed.
Let me ask this way: Is RULES_JAVA supported? Is there any better solution?
What is "standard" build mechanism for EPICS Java application?
Nerses
----- Original Message -----
To: "Nerses Gevorgyan" <[email protected]>, [email protected]
Sent: Tuesday, September 16, 2014 10:50:44 AM
On 9/15/14, 11:00 PM, Nerses Gevorgyan wrote:
> The Makefile is quite simple.
> vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
> TOP=../..
> JAVA_DIR = ~rafopar/Apps/Java/jdk1.7.0_67
Hi, Nerses.
I've never used RULES_JAVA, so I'm not commenting on any of your
reported problems, except I will say that your use of a tilde character
('~') in your JAVA_DIR path might be a problem.  That is normally a
special syntax recognized by certain shells that will be expanded to a
user's home directory.  That might not work as you're expecting in GNU
Make.  I suggest replacing that with an absolute path.
Lewis
Re: Is RULES_JAVA broken? J. Lewis Muir
Re: Is RULES_JAVA broken? Andrew Johnson
Prev: Re: Question about asyn and offline device Sonya Hoobler
Next: Re: Is RULES_JAVA broken? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Is RULES_JAVA broken? J. Lewis Muir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
