Hi Torsten,
Thanks for you response and sorry for my delayed reply; I'm catching up
after being away.
Just curious: Why are they offlien ?
Is this intended, is it a problem with the network, or do the devices have
problems their selves?
They can be offline because of temporary outages or being added to the
monitoring soft ioc in advance of coming online.
When the soft IOC is exiting, why does it try to connect to a device ?
(Or is it at the start of the IOC ?)
(Or do you start the IOC and stop it shortly after the start ?
The soft ioc does not try to connect to the device as part of exit. The
soft ioc is repeatedly trying to connect to the device and so it is
usually in the middle of connect() when a user tries to exit.
Do we know why does it take 3 minutes ?
On a Debian Linux
"time telnet 10.0.0.1" reports 1 minute, 3 seconds, and the Scientific Linux
6.5 system reports the same
What does
"time telnet 10.0.0.2" give on your system ?
On our system, time telnet 10.0.0.2 returns 3m9.048s.
What would happen if we do like this:
(diff is taken from latest, so the line number may by different)
diff --git a/asyn/drvAsynSerial/drvAsynIPPort.c
b/asyn/drvAsynSerial/drvAsynIPPort.c
index 07b96d3..2b2cfe6 100644
--- a/asyn/drvAsynSerial/drvAsynIPPort.c
+++ b/asyn/drvAsynSerial/drvAsynIPPort.c
@@ -236,6 +236,7 @@ cleanup (void *arg)
ttyController_t *tty = (ttyController_t *)arg;
if (!tty) return;
+ epicsSocketDestroy(tty->fd);
status=pasynManager->lockPort(tty->pasynUser);
if(status!=asynSuccess)
asynPrint(tty->pasynUser, ASYN_TRACE_ERROR, "%s: cleanup locking
error\n", tty->portName);
@@ -243,7 +244,6 @@ cleanup (void *arg)
if (tty->fd != INVALID_SOCKET) {
asynPrint(tty->pasynUser, ASYN_TRACE_FLOW, "%s: shutdown socket\n",
tty->portName);
tty->flags |= FLAG_SHUTDOWN; /* prevent reconnect */
- epicsSocketDestroy(tty->fd);
tty->fd = INVALID_SOCKET;
/* If this delay is not present then the sockets are not always
really closed cleanly */
epicsThreadSleep(CLOSE_SOCKET_DELAY);
This would not work because while the device is not connected, there is no
active socket and so no socket to destroy. You can see this in the
connectIt() routine.
Sonya
On Thu, 11 Sep 2014, Torsten Bögershausen wrote:
On 10/09/14 00:28, Sonya Hoobler wrote:
Hi Mark,
At LCLS we have VME crates (and other devices) that we monitor and control
with soft iocs using asyn + streamdevice.
There are many crates and it is not uncommon for one or more to be offline.
We have noticed that if there is an offline device, it can take minutes for
the monitoring soft ioc to exit.
This delay is the time it takes for the connect() networking routine to try
to connect to the offline device.
the socket is blocking and connect() takes about 3 minutes on our system.
On a Debian Linux
What does
(More detail: the delay occurs while drvAsynIPPort cleanup() waits for the
synchronousLock mutex.
The mutex is held by asynManager portThread() or connectAttempt() while
drvAsynIPPort connectIt() calls connect().)
I am curious what your thoughts are on this and whether you think it is
worthwhile to pursue a change to reduce the shutdown time under these
conditions.
One option could be to modify connectIt() to temporarily set the socket to
non-blocking during connect() and use select() to enforce a specified
timeout.
Then the socket could be set back to blocking. One potential downside of
this could be introducing a new timeout which might not suit all systems.
A little more detail about our system: the soft iocs run on Linux RHEL5
32-bit servers,
Isn't it that the cleanup() want to call epicsSocketDestroy(), which should
result in a a simple close().
But, it is blocked because of the lockPort(), we need to wait for connect()
to fail.
if (!tty) return;
tty->portName);
soon to be RHEL6 64-bit. We are using base R3-14-12, asyn4-21,
streamdevice-R2-5, TCP/IP telnet-style connections, e.g.:
drvAsynIPPortConfigure ("crat-test-bd01","crat-test-bd01:23",0,0,0)
Sonya
Sonya Hoobler
SLAC National Accelerator Laboratory
[email protected]
- Question about asyn and offline device Sonya Hoobler
- Re: Question about asyn and offline device Torsten Bögershausen
Re: Is RULES_JAVA broken? J. Lewis Muir
Re: Is RULES_JAVA broken? Nerses Gevorgyan
<2014>
2025
2026
EPICSQt version 2.9.0 released Andrew Rhyder
<2014>
2025
2026
