1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is RULES_JAVA broken?
To: Nerses Gevorgyan <[email protected]>
Cc: [email protected]
Date: Tue, 16 Sep 2014 14:37:02 -0500
On 9/16/14, 12:58 PM, Nerses Gevorgyan wrote:
> Let me ask this way: Is RULES_JAVA supported? Is there any better
> solution?  What is "standard" build mechanism for EPICS Java
> application?
Hi, Nerses.
I don't build any of my EPICS CA Java applications or libraries with the
EPICS Base build framework.  But I don't want to rule that out for you
because there may be people using it; I'm just not one of them.
When you say "EPICS Java application," what do you mean?  Java libraries
and applications that I write only interface with EPICS via Channel
Access (CA).  To do this, they need an EPICS CA library.  One such
library is JCA/CAJ [1].  It's confusing, unfortunately, but JCA is a
set of Java classes and interfaces as well as a JNI implementation
for using native EPICS CA libraries from EPICS Base.  JCA does not
include the native EPICS CA libraries from EPICS Base; you'd have to
build or obtain them separately.  CAJ is a 100% Java implementation of
the interfaces provided in JCA; it does not require native EPICS CA
libraries from EPICS Base.  So, for a 100% pure Java EPICS CA library
for the Java libraries and applications I write, I use the Java classes
and interfaces from JCA with the Java implementation from CAJ, and I
refer to this as "JCA/CAJ."  This solution requires no native EPICS CA
Given this, I build my EPICS CA Java applications and libraries like
any other Java application or library; I use Ant [2].  The "JCA/CAJ"
library dependency is just two JAR files: jca-[VERSION].jar and
caj-[VERSION].jar.  I treat them like I would any other library
dependency.  Obviously, another very popular choice for building Java
applications and libraries is Maven [3]; you could use that instead of
Ant if you prefer.
Lewis
[1] http://epics-jca.sourceforge.net/
[2] http://ant.apache.org/
[3] http://maven.apache.org/
Re: Is RULES_JAVA broken? Nerses Gevorgyan
Prev: Re: Is RULES_JAVA broken? Nerses Gevorgyan
Next: Re: Is RULES_JAVA broken? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Is RULES_JAVA broken? Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
