1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is RULES_JAVA broken?
To: Benjamin Franksen <[email protected]>, [email protected]
Date: Tue, 16 Sep 2014 15:16:04 -0500
On 9/16/14, 2:40 PM, Benjamin Franksen wrote:
> Hi Lewis
> Gnu make by default uses /bin/sh to execute recipes (one invocation
> per line), which should be a posix conformant(*) shell and thus
> support tilde expansion.  For make itself, the tilde is just another
> character with no special meaning.
Hi, Ben.
Right, I'm aware of that, but the problem is the assumption that the
RULES_JAVA value will be passed to the default shell to be expanded
before being used.  That's an invalid assumption.
> The problem is that makefiles sometimes do non-trivial processing of
> make variables before using them in recipes, where they (hopefully)
> get expanded by the shell. This is very common in EPICS. If this
> processing is written in a way that, for instance, expects an absolute
> path to start with a '/' then this processing will fail even though
> the shell will expand it to one.
Another case is if the value is used in the default shell in single
quotes thereby disabling the shell's tilde expansion.
> (*) Interestingly, neither my spell checker nor Webster knows this
> word, but I've read it many, many times in English texts so it can't
> be completely wrong, or can it?
Same for me. :-)  I'm sure it's correct.  Maybe it's mostly used in
engineering, science, or technical circles, and it hasn't hit the
mainstream free English dictionaries (yet?).  I bet the OED has it, but
I don't have access to that; it costs an arm and a leg.
Lewis
Is RULES_JAVA broken? Nerses Gevorgyan
Re: Is RULES_JAVA broken? J. Lewis Muir
Re: Is RULES_JAVA broken? Benjamin Franksen
Prev: Re: Is RULES_JAVA broken? Benjamin Franksen
Next: Re: Is RULES_JAVA broken? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Asyn model 3 driver for Galil products Mark Clift
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
