1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compile on Windows XP with MinGW
To: "tech-talk\@aps.anl.gov" <[email protected]>
Date: Fri, 24 Oct 2014 10:50:35 +0300
Mark Rivers <[email protected]> writes:
>> On Oct 22, 2014, at 1:17 PM, Zunbeltz Izaola <[email protected]> wrote:
>> ../../../src/libCom/osi/os/WIN32/osdTime.h:21: error: redefinition of
>> `struct ti
>> mespec'
>> /usr/include/sys/types.h:76: error: previous definition of `struct timespec'
>> In file included from ../../../src/libCom/osi/os/WIN32/osdSock.h:23,
>>                from ../../../src/libCom/osi/osiSock.h:21,
>>                from ../../../src/libCom/fdmgr/fdManager.h:28,
>>                from ../../../src/libCom/fdmgr/fdmgr.cpp:29:
>> /usr/lib/gcc/i686-pc-msys/3.4.4/../../../../include/w32api/winsock2.h:103:2:
>> war
This suggests that gcc compiler, version 3.4.4, was used. It is
rather old (and probably also mingw runtime and w32api were old versions).
I tested building epics base in mingw/msys environment, gcc version
4.8.1, obtained from http://www.mingw.org/
There was minor problem in while compiling, the same as in
https://bugs.launchpad.net/epics-base/+bug/1352832
Otherwise, no problems.
Jani Hakala
University of Jyväskylä, Department of Physics
email:  [email protected]
compile on Windows XP with MinGW Zunbeltz Izaola
Re: compile on Windows XP with MinGW Mark Rivers
Prev: Re: compile on Windows XP with MinGW zunbeltz
Next: Re: Possible to close a TCP/IP socket in asyn? Adam Bark
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: asyndriver : Multiple drvAsynIPPort Patel Jignesh
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
