1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compile on Windows XP with MinGW
Date: Fri, 24 Oct 2014 09:08:14 +0200
Thanks for the recomendations.
I change to MS Visual Studio Express and I managed to compile it.
Zunbeltz
og., 2014.eko urrren 23a 21:31(e)an, Mark Rivers igorleak idatzi zuen:
Sent from my iPhone
On Oct 22, 2014, at 1:17 PM, Zunbeltz Izaola <[email protected]> wrote:
I am trying to compile on windows.
I downloaded the MinGW bundle and set the EPICS_HOST_ARCH to WIN32-X86-mingw.
When I first run make on base-3.14.12.4
I get and error that direct.h could not be found.
I fix this by setting C_INCLUDE_PATH to /c/MinGW/include where there is a
direct.h file.
But then I got the following error
g++ -c             -D_MINGW     -O3   -Wall      -m32    -D_DLL   -MMD -I.
-I../
O.Common -I. -I../../../src/libCom/osi/os/WIN32
-I../../../src/libCom/osi/os/pos
ix -I../../../src/libCom/osi/os/default -I..
-I../../../src/libCom/bucketLib -I.
./../../src/libCom/ring -I../../../src/libCom/calc
-I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/
libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../sr
c/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
-I../.
./../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/logClie
nt -I../../../src/libCom/macLib -I../../../src/libCom/misc
/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/lib
Com/tsDefs -I../../../include/os/WIN32 -I../../../include
../../../src/li
bCom/fdmgr/fdmgr.cpp
In file included from ../../../src/libCom/osi/epicsTime.h:19,
                from ../../../src/libCom/fdmgr/fdManager.h:27,
                from ../../../src/libCom/fdmgr/fdmgr.cpp:29:
../../../src/libCom/osi/os/WIN32/osdTime.h:21: error: redefinition of
`struct ti
mespec'
/usr/include/sys/types.h:76: error: previous definition of `struct timespec'
In file included from ../../../src/libCom/osi/os/WIN32/osdSock.h:23,
                from ../../../src/libCom/osi/osiSock.h:21,
                from ../../../src/libCom/fdmgr/fdManager.h:28,
/usr/lib/gcc/i686-pc-msys/3.4.4/../../../../include/w32api/winsock2.h:103:2:
war
ning: #warning "fd_set and associated macros have been defined in sys/types.
This may cause runtime problems with W32 sockets"
make[3]: *** [fdmgr.o] Error 1
make[3]: Leaving directory `/c/base-3.14.12.4/src/libCom/O.WIN32-x86-mingw'
make[2]: *** [install.WIN32-x86-mingw] Error 2
make[2]: Leaving directory `/c/base-3.14.12.4/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/c/base-3.14.12.4/src'
make: *** [src.install] Error 2
Any idea what is going wrong?
Is there other preferred way to compile EPICS on windows XP 32bit?
Thanks in advance for you help,
Zunbeltz
You can use the free version of Visual Studio. I don't know why mingw is not working.
Dr. Zunbeltz Izaola
Accelerator Physics Group
ESS-Bilbao
compile on Windows XP with MinGW Zunbeltz Izaola
Re: compile on Windows XP with MinGW Mark Rivers
Prev: Re: Focus deadlock nick.rees
Next: Re: compile on Windows XP with MinGW Jani Hakala
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: compile on Windows XP with MinGW Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
