1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NaN and analog records
To: <[email protected]>
Date: Tue, 4 Nov 2014 14:17:45 +0100
On Tuesday 04 November 2014 13:41:00 Ralph Lange wrote:
> Hello Götz,
> On 04/11/2014 13:32, Goetz Pfeiffer wrote:
> > another problem is that DRVL and DRVH seem to be ignored for NaN.
> > The following record;
> > record(ao,"UE56ID3R:BaseParGapTrs") {
> >      field(ASG,"USERCTL")
> >      field(DRVH,"0.1")
> >      field(DRVL,"0")
> >      field(LINR,"NO CONVERSION")
> >      field(OIF,"Full")
> >      field(PREC,"4")
> > for example can be set to NaN (at least for Epics Base 3.14.8).
> Comparisons between numbers and non-numbers (such as NaN) are
> undefined.
I am quite sure neither the C standard(s) nor IEEE 754 say this is
undefined. Rather, IIRC, comparisons involving NaN always result in a
FALSE value, including the test for equality of a variable with itself.
> What is your suggestion on how to check limits for a
> non-number without using comparisons?
The more interesting question is: what should the resulting VAL be, if
not NaN?
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
NaN and analog records Benjamin Franksen
Re: NaN and analog records Goetz Pfeiffer
Re: NaN and analog records Ralph Lange
Prev: Re: NaN and analog records Goetz Pfeiffer
Next: Re: NaN and analog records Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: NaN and analog records michael.abbott
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
