1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: NaN and analog records
To: <[email protected]>, <[email protected]>
Date: Tue, 4 Nov 2014 13:37:33 +0000
> Comparisons between numbers and non-numbers (such as NaN) are
> undefined.
Not quite: comparisons involving NaN are defined to always return false.  This means that a test of the form
	if (prec->drvl <= value && value <= prec->drvh)
	    // accept value
	else
	    // reject value
would have the desired effect (and setting a drv limit would cause all values to be rejected!)
> What is your suggestion on how to check limits for a non-number without
> using comparisons?
> > We also found that you can type "NaN" at any entry field in DM2K
> which
> > writes NaN directly to the PV.
> NaN, -inf and +inf are valid values for a double. Why would you reject
> entering valid values in entry fields?
> Cheers,
> ~Ralph
Re: NaN and analog records Dirk Zimoch
NaN and analog records Benjamin Franksen
Re: NaN and analog records Goetz Pfeiffer
Re: NaN and analog records Ralph Lange
Prev: Re: NaN and analog records Ralph Lange
Next: support for NIKHEF Hall probes Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NaN and analog records Benjamin Franksen
Next: Re: NaN and analog records Dirk Zimoch
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
