1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: FW: EPICS 3.15.1
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 03 Dec 2014 16:58:55 +0100
While we're at it...
On 03/12/2014 16:44, Mooney, Tim M. wrote:
For any synApps module, you should include <module>Support.dbd, and not <module>.dbd, because <module>.dbd is what the module builds for its own use, while <module>Support.dbd is what it builds for export to other modules.  For autosave, the names are as.dbd and asSupport.dbd.
This is indeed the synApps model of naming things, but synApps is a bit special in this regard.
The more common pattern is to have <module> export <module>.dbd for inclusion by applications, and I would lean towards proposing synApps make a step in that direction.
What is "its own use" for a support module anyway? By definition, a support module provides a library and resource files (like dbd files and db templates) that go with it. Tests and examples should rather be moved into embedded self-contained TOP structures - 3.15 provides convenient Makefile rules to do that. This has multiple advantages: it clearly separates support module and example code (inexperienced users usually can't tell which is which in the existing mixed modules, and create worse applications as a result), and it allows simply copying out the complete embedded example tree into their own work area (requiring only a change in the configure/RELEASE file to locally build a correct full example app).
Just my 2.5ct...
~Ralph
RE: FW: EPICS 3.15.1 Mooney, Tim M.
EPICS 3.15.1 Dudley, David
FW: EPICS 3.15.1 Dudley, David
RE: FW: EPICS 3.15.1 Dudley, David
Re: FW: EPICS 3.15.1 Michael Davidsaver
Prev: RE: FW: EPICS 3.15.1 Mooney, Tim M.
Next: RE: FW: EPICS 3.15.1 Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: FW: EPICS 3.15.1 Mooney, Tim M.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
