1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: FW: EPICS 3.15.1
Date: Wed, 3 Dec 2014 16:05:52 +0000
So, slowly this is coming together.
Looks like the combined history of all the IOCs that were built in the past for NSCL/FRIB is coming back to bite it, now that the restrictions are being tightened (actually, a GOOD thing).
A number of modules in the Makefile were duplicated several times from various *.dbd includes.
Fixing those problems corrected the issue.
Thanks Andrew, Michael, Tim...
Things are going OK for the first, easy IOC.  Now, to proceed on.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7133
Email: [email protected]
-----Original Message-----
Sent: Wednesday, December 03, 2014 10:44 AM
To: [email protected]; Dudley, David; [email protected]
For any synApps module, you should include <module>Support.dbd, and not <module>.dbd, because <module>.dbd is what the module builds for its own use, while <module>Support.dbd is what it builds for export to other modules.  For autosave, the names are as.dbd and asSupport.dbd.
If you include calcSupport.dbd, you shouldn't include any <record>.dbd files that are included by calcSupport.dbd.
The strategy I've been using for 3.15 is that no module should have record types in the .dbd file it exports that are actually provided by base or some other module.  Some synApps modules needed to be modified to do this, and not all of the new modules have been released, though nearly all have been tagged.
asyn is a problem, because asyn.dbd includes asynRecord.dbd.  This means modules mustn't include asyn.dbd in their <module>Support.dbd files, else several modules will in effect be claiming to provide asynRecord.dbd.
Tim Mooney ([email protected]) (630)252-5417 Software Services Group (www.aps.anl.gov) Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Michael Davidsaver [[email protected]]
Sent: Wednesday, December 03, 2014 8:39 AM
To: Dudley, David; [email protected]
Subject: Re: FW: EPICS 3.15.1
On 12/03/2014 09:34 AM, Dudley, David wrote:
> Thanks for the suggestion.  The as.dbd file may have been a contributing problem, but not the 'only' one, in any case.
It's still there (see below).
> So, from your comment, it sounds like I'm going to have to go through all the driver modules, and somehow insure that none of them include the base types in their .dbd files?
Yes.
> perl -CSD /home/dudleyd/R3.15.1/bin/linux-x86_64/dbdExpand.pl  -I.
> -I.. -I../O.Common -I../../../dbd -I/home/dudleyd/R3.15.1/dbd
> -I/home/dudleyd/R3.15.1/dbd -I/home/dudleyd/R3.15.1/dbd -o
> BACNetApp.dbd base.dbd sscan.dbd aCalcoutRecord.dbd calcSupport.dbd
> sCalcoutRecord.dbd swaitRecord.dbd transformRecord.dbd plcAdmin.dbd
> as.dbd asSupport.dbd iocAdmin.dbd devIocStats.dbd system.dbd
> epics2bacnet.dbd IncSetRecord.dbd
Note that now both as.dbd and asSupport.dbd are being included.
EPICS 3.15.1 Dudley, David
FW: EPICS 3.15.1 Dudley, David
RE: FW: EPICS 3.15.1 Dudley, David
Re: FW: EPICS 3.15.1 Michael Davidsaver
Prev: Re: FW: EPICS 3.15.1 Ralph Lange
Next: Re: Using EPICS with Attocube stepper motor Ana Malagon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: FW: EPICS 3.15.1 Mooney, Tim M.
Next: RE: FW: EPICS 3.15.1 Dudley, David
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
