1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: FW: EPICS 3.15.1
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 04 Dec 2014 15:25:35 +0100
On 04/12/2014 14:50, Mark Rivers wrote:
It keeps the module, its tests and examples nicely in the same source
structure (= code repository), which is good as they are usually
developed in parallel.
Where is this documented?  I took a quick look in the 3.15.1 Application Developer's Guide and did not find it.
Does the 3.15 makeBaseApp.pl script or some other script have an example of how to use this?
Ehhm... Excellent points, actually.
As far as I recall, creating a directory named *Top in the top level of your support module is (read: should be) sufficient. This e.g. "exampleTop" contains the complete embedded (possibly makeBaseApp-generated) TOP structure, with configure/RELEASE pointing to "$(TOP)/.." for the support module it is embedded in. Some of the EPICS V4 modules were the first ones to use this.
Sorry,
~Ralph
EPICS 3.15.1 Dudley, David
FW: EPICS 3.15.1 Dudley, David
RE: FW: EPICS 3.15.1 Dudley, David
Re: FW: EPICS 3.15.1 Michael Davidsaver
RE: FW: EPICS 3.15.1 Mooney, Tim M.
Re: FW: EPICS 3.15.1 Ralph Lange
RE: FW: EPICS 3.15.1 Mark Rivers
Prev: RE: 3.15.1 DB Build Issue Dudley, David
Next: Re: Sorenson SGA DC power supplies Mark Davis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: FW: EPICS 3.15.1 Mark Rivers
Next: RE: FW: EPICS 3.15.1 Mooney, Tim M.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
