1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input?
To: <[email protected]>
Date: Wed, 17 Dec 2014 15:12:11 -0600
Hi Mark,
On 12/17/2014 01:42 PM, Mark Rivers wrote:
> Questions:
> The way I have currently written it the info field is only read
> during init_record.  This means that this feature if set at iocInit,
> and cannot be turned on and off at runtime.  Is this OK?
> It seems to me that it is because:
> - I don't think one can access the info tags over Channel Access so
> one would need to type a "dbpf" command to the IOC to change the
> setting.
> - The info tags are not Process Passive so one would need to force
> the record to process to have it read the info tag again?
> Is the info tag approach acceptable, and if so is the name CALLBACK
> OK?
Info tags are not fields, they are just a way of loading metadata for a
record from a .db file. As you said above you can't get at them through
CA, or even through dbpf — there are deliberately no iocsh commands
provided for manipulating them at runtime. You could however provide
your own command that would find the record, set the info item and also
trigger the device support to adjust its settings to match. It should
lock the record while it's doing that though.
I might suggest using some kind of namespace (e.g. asyn:CALLBACK or
asyn.CALLBACK) to distinguish asyn-specific info tag names, although
it's probably a bit late for me to suggest that now.
I don't see CALLBACK as obviously describing the functionality that
you're providing, so I would encourage you to look for a better name;
how about asyn:DUPLEX or asyn:READBACK instead?
HTH,
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Heesterman, Peter J
RE: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? nick.rees
Re: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Ralph Lange
RE: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Mark Rivers
Prev: RE: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Mark Rivers
Next: Re: CA Gateway 2.0.5.0 released Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Ralph Lange
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
