On 15/12/2014 18:10, Benjamin Franksen wrote:
Am Freitag, 12. Dezember 2014, 20:42:16 schrieb Ralph Lange:
Hi Freddie,
Note that for the gateway part, I published a fix release 2.0.5.1 on
Monday, which contains the same or equivalent fixes for everything you
have in your patch. Thanks, anyway - sorry that you had to go through
the same mess...
As for the caPutLog part, that's not me. I agree with Andrew that
removing the epicsShareAPI would be the way to go. Are the maintainers
listening? Please?!
Hm, that would be me I guess. So is removing epicsShareApi the consensus or
not? If there are inconsistencies between .c and .h files in caPutLog I will
fix them in favor of whatever you think is more useful.
Yes, please remove the epicsShareAPI declaration.
This decoration (that affects the way arguments are passed from caller
to function) should only be applied to functions that are intended to be
called from other programming languages with possibly different
parameter-passing conventions.
Thanks a lot,
~Ralph
- CA Gateway 2.0.5.0 released Ralph Lange
- RE: CA Gateway 2.0.5.0 released freddie.akeroyd
- Re: CA Gateway 2.0.5.0 released Ralph Lange
- Re: CA Gateway 2.0.5.0 released Benjamin Franksen
Re: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Andrew Johnson
Job openings at ESS Timo Korhonen
<2014>
2025
2026
RE: connecting EPICS to a Beckhoff PLC [SEC=UNCLASSIFIED] LYNCH, Damien
<2014>
2025
2026
