Hi Gongyu,
On 01/27/2015 09:24 AM, GONG Yu wrote:
> During builing of EPICS base in this time, there is no errors that I came accross last time. It is likely that I missed the libstdc++-devel components in the installing of g++ last time.
> The last several lines goes like these:
> mkdir ../../../lib/perl/5.8.8
> mkdir ../../../lib/perl/5.8.8/i386-linux-thread-multi
> Installing script ../../../bin/linux-x86/cainfo.pl
> Installing script ../../../bin/linux-x86/caput.pl
> Installing script ../../../bin/linux-x86/caget.pl
> Installing script ../../../bin/linux-x86/capr.pl
> Installing script ../../../bin/linux-x86/camonitor.pl
> rm -f CA.html
> podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
> ../CA.pm pod syntax OK.
> Installing html ../../../html/./CA.html
> rm CA.html
> make[3]: Leaving directory `/home/gongyu/EPICS/base-3.14.12.4/src/cap5/O.linux-x86'
> make[2]: Leaving directory `/home/gongyu/EPICS/base-3.14.12.4/src/cap5'
> make[1]: Leaving directory `/home/gongyu/EPICS/base-3.14.12.4/src'
> I wonder if the building of EPICS base succeeds.
Yes, those are the last lines you should see after a successful build of
3.14.12.4. If you want to you can run the built-in self-tests as well by
typing 'make runtests' at the top of the build tree, but this is optional.
> Following your suggestion, here I build the EPICS base-3.14.12.4, besides,
> base-3.14.12 (which is also built for test) gives these similar
results.
If you can use the newer version I would recommend that as it has some
known bugs fixed.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
against your wishes, and doesn't give you the key, they're
not doing it for your benefit.
- Problem building epics base under CentOS 5.6 GONG Yu
- Re: Problem building epics base under CentOS 5.6 Andrew Johnson
- Re: Re: Problem building epics base under CentOS 5.6 GONG Yu
RE: caQtDM Mark S. Engbretson
<2015>
2025
2026
Checking which record triggered processing Tobiasz Czopowicz
<2015>
2025
2026
