1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: related to coding
To: priya tiwari <[email protected]>, Mark Engbretson <[email protected]>
Date: Mon, 2 Feb 2015 12:42:30 +0000
One problem is that you used upper-case for VAL.  In the aiRecord.h file that is lower-case.  It is upper case only when using the PV name.
So change this:
precord->VAL=3;
e=precord->VAL;
to this:
precord->val=3;
e=precord->val;
The compiler is clear about other errors too, like that precord->DOUBLE does not exist, etc.
From: [email protected] [[email protected]] on behalf of priya tiwari [[email protected]]
Sent: Monday, February 02, 2015 12:05 AM
To: Mark Engbretson
Cc: [email protected]
Subject: Re: related to coding
sorry sir this is compile time error, What would be the solution of this problem? Actually i want to write a simple code for putting a value in VAL field of ai record.
On Mon, Feb 2, 2015 at 10:47 AM, Mark Engbretson <[email protected]<mailto:[email protected]>> wrote:
Note: these are NOT run time errors, your code doesn't even compile.
Sent from my iPad 4
On Feb 1, 2015, at 23:05, priya tiwari <[email protected]<mailto:[email protected]>> wrote:
Thanks Sir,
I changed in a code but still i got the errors at run time.please provide me solution.
On Mon, Feb 2, 2015 at 9:50 AM, Mooney, Tim M. <[email protected]<mailto:[email protected]>> wrote:
Hi Priya,
Return 2, instead of 0, from read_ai.  That tells the record that you put the value in VAL.  If you return 0, you are telling the record you put the value in RVAL, and that the record should convert RVAL to get VAL.
See "Device Support Routines" in
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Analog_Input
Tim Mooney ([email protected]<mailto:[email protected]>) (630)252-5417
Software Services Group (www.aps.anl.gov<http://www.aps.anl.gov>)
Advanced Photon Source, Argonne National Lab
From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] on behalf of priya tiwari [[email protected]<mailto:[email protected]>]
Sent: Sunday, February 01, 2015 9:54 PM
To: [email protected]<mailto:[email protected]>
Subject: related to coding
Hello,
I am trying to write the value into val field of ai record from device support.I am beginner in EPICS so I have no idea about this. But i have tried then i got the errors at run time please help me.I am attaching code file.
Thanks in advance...
<Screenshot from 2015-02-02 10:30:06.png>
<dbtest.c>
related to coding priya tiwari
RE: related to coding Mooney, Tim M.
Re: related to coding priya tiwari
Re: related to coding Mark Engbretson
Prev: Re: related to coding priya tiwari
Next: Remote Controlled Power Distribution Units? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
