1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using the EPICS Build/Make system to build kernel modules for linux
From: "Williams Jr., Ernest L." <[email protected]>
To: Jameson Graef Rollins <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 19 Feb 2015 07:14:33 +0000
Hi Jamie,
Sent: Wednesday, February 18, 2015 9:18 AM
To: Williams Jr., Ernest L.; [email protected]
Subject: Re: Using the EPICS Build/Make system to build kernel modules for linux
On Thu, Feb 12 2015, "Williams Jr., Ernest L." <[email protected]> wrote:
> As I begin this task; maybe someone else has already done it :)
> We typically have kernel module source from hardware vendors that we recompile for our target architectures
> In my case, I have the following architectures:
> (1) linux-x86                         (RHEL6 32-bit)
> (2) linux-x86_64                 (RHEL6  64-bit)
> (3) linuxRT-x86                    (32-bit linux w/realtime patch and ucLibc)
> (4) linuxRT-x86_64            (64-bit linux w/realtime patch and ucLibc)
> (5) linuxRT_glibc-x86_64  (64-bit linux w/realtime patch and gLibc)
> I would like to hi-jack the EPICS Make system framework to build kernel modules.
I'm so sorry, but I feel compelled to speak out that the EPICS build
system is one of the more obscure, convoluted, and unfriendly to work
with as I have seen.  It makes packaging EPICS and related software
extremely difficult.  I would strongly advise against using it as a
prototype for other projects.
What are you using now?
And what do you propose?
Cheers,
Ernest
jamie.
RE: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
Using the EPICS Build/Make system to build kernel modules for linux Williams Jr., Ernest L.
Re: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
Prev: Re: Error in EDM-1-12-98 installation Rahul Jain
Next: CSS : Label display precision Amien Crombie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
Next: RE: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
