1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using the EPICS Build/Make system to build kernel modules for linux
To: "Williams Jr.\, Ernest L." <[email protected]>, "tech-talk\@aps.anl.gov" <[email protected]>
Date: Tue, 24 Feb 2015 09:43:12 -0800
>> As I begin this task; maybe someone else has already done it :)
>> We typically have kernel module source from hardware vendors that we recompile for our target architectures
>> In my case, I have the following architectures:
>> (1) linux-x86                         (RHEL6 32-bit)
>> (2) linux-x86_64                 (RHEL6  64-bit)
>> (3) linuxRT-x86                    (32-bit linux w/realtime patch and ucLibc)
>> (4) linuxRT-x86_64            (64-bit linux w/realtime patch and ucLibc)
>> (5) linuxRT_glibc-x86_64  (64-bit linux w/realtime patch and gLibc)
>> I would like to hi-jack the EPICS Make system framework to build kernel modules.
> I'm so sorry, but I feel compelled to speak out that the EPICS build
> system is one of the more obscure, convoluted, and unfriendly to work
> with as I have seen.  It makes packaging EPICS and related software
> extremely difficult.  I would strongly advise against using it as a
> prototype for other projects.
> What are you using now?
> And what do you propose?
I probably should have kept my mouth shut, since I don't actually know
what you're looking for, nor do I have any good suggestions for
alternatives.  That said, my packaging experience leads me to strongly
prefer build systems that work in "standard" ways, and don't for
instance require in-tree builds for linking applications, which EPICS
currently requires (modulo the packaging ninjitsu accomplished by the
EPICS Debian packagers).
jamie.
Attachment: signature.asc
Description: PGP signature
Re: Using the EPICS Build/Make system to build kernel modules for linux J. Lewis Muir
RE: Using the EPICS Build/Make system to build kernel modules for linux Williams Jr., Ernest L.
Re: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
Prev: Re: Begginer with EPICSv4 Kasemir, Kay
Next: Re: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Using the EPICS Build/Make system to build kernel modules for linux Williams Jr., Ernest L.
Next: Re: Using the EPICS Build/Make system to build kernel modules for linux J. Lewis Muir
