1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "No conversion between src & dest" warning with pcaspy
To: Jameson Graef Rollins <[email protected]>, "Kasemir, Kay" <[email protected]>
Cc: Epics <[email protected]>
Date: Tue, 3 Mar 2015 19:47:58 +0000
Since this is a pcaspy only bug, I created the report in the project issue tracker.
https://code.google.com/p/pcaspy/issues/detail?id=14
Thanks for the detective work to reveal the bug.
Best
Xiaoqiang
> On 03 Mar 2015, at 18:54, Jameson Graef Rollins <[email protected]> wrote:
> On Tue, Mar 03 2015, "Kasemir, Kay" <[email protected]> wrote:
>> On Mar 3, 2015, at 12:19 PM, Andrew Johnson <[email protected]>
>> wrote:
>>> On 03/03/2015 11:04 AM, Kasemir, Kay wrote:
>>>> Until the PV is initialized, I get the same
>>>> No conversion between src & dest types no conversion between event
>>>> app type=16 and DBR type=18 Element count=60
>>>> error.
>>> The implication is that pcaspy is presenting an uninitialized channel's
>>> value to the cas as some type which gdd can't convert into to an array
>>> of chars. The answer may be as simple as always initializing the value
>>> of a string channel to be an empty string.
>> .. which I just found can be done like this:
>>  self.setParam('ThatPV', [ 0 ])
>> That seems to work for clients that look for a long string, since they end on the first '\0'.
> Interesting.  I can confirm this works as well.  In fact, just setting
> the initial 'value' to [0] in the database definition does the trick as
> well:
>    'STR': {
>        'type': 'char',
>        'count': 60,
>        'value': [0],
> Thanks for the sleuthing, Kay.  Maybe we can put together a patch that
> changes how these records are initialized inside of pcaspy.
> I just realized that camonitor is showing worse behavior than MEDM in
> regards to these improperly initialized records; it just hangs with no
> output at all until a valid value has been written to the array.
> jamie.
Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
Re: "No conversion between src & dest" warning with pcaspy Andrew Johnson
Re: "No conversion between src & dest" warning with pcaspy Kasemir, Kay
Prev: Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
Next: error on the IOC shell for asyn driver Vishnu Patel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
