1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "No conversion between src & dest" warning with pcaspy
To: "Wang Xiaoqiang \(PSI\)" <[email protected]>, "Kasemir\, Kay" <[email protected]>
Cc: Epics <[email protected]>
Date: Tue, 03 Mar 2015 13:40:09 -0800
On Tue, Mar 03 2015, "Wang Xiaoqiang (PSI)" <[email protected]> wrote:
> Since this is a pcaspy only bug, I created the report in the project issue tracker.
> https://code.google.com/p/pcaspy/issues/detail?id=14
> Thanks for the detective work to reveal the bug.
Hey, Xiaoqiang.  I think the problem might actually be more insidious
than I originally thought.  It seems that if the value for a char array
is every set to an array of null bytes this described error will be
thrown when a monitoring clients connects to the channel.  Clients that
are already connected to the channel will also throw an error and not
update their values if the value is set to an array of null bytes.
I thought before that this problem was relatively innocuous, since it
would have only been a startup problem.  But now I see that whenever my
pcaspy application clears the char array PV, all connected clients show
the bad behavior.
I haven't had any luck tracking down where in the pcaspy the problem may
be coming from.
jamie.
Attachment: signature.asc
Description: PGP signature
Re: "No conversion between src & dest" warning with pcaspy Wang Xiaoqiang (PSI)
"No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
Re: "No conversion between src & dest" warning with pcaspy Andrew Johnson
Re: "No conversion between src & dest" warning with pcaspy Kasemir, Kay
Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
Prev: RE: error on the IOC shell for asyn driver Mark Rivers
Next: How to handle out-of-index of MBBO/MBBI? Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "No conversion between src & dest" warning with pcaspy Wang Xiaoqiang (PSI)
Next: Re: "No conversion between src & dest" warning with pcaspy Wang Xiaoqiang (PSI)
