1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: How to handle out-of-index of MBBO/MBBI?
To: EPICS tech-talk <[email protected]>
Date: Wed, 04 Mar 2015 14:12:14 +0900
In order to make my head clean from the project management, I am doing to write an IOC for the Keithley 6514 electrometer currently. ECR Ion source team has a Faraday cup, they want to use that Keithley model to record the extracted beam current with the remote or serial connection.
I've found some already developed Keithley IOCs from EPICS sites, and google-found-sites, and learned how other people uses it within the EPICS framework. They are excellent to glimpse a functionality before I start to work on it.
  The developed IOC works fine with a simple and basic functionality.
This unit has two ways to setup the integration time of the A/D converter. The first way is to use a selected value between 0.01 and 10. The second one is to use the predefined values, such as SLOW, MED, and FAST. The end user wants to use only the predefined values (SLOW, MED, and FAST).
--- DB file ---
record(mbbo, "$(SYS)-$(SUBSYS):$(DEV):SetADRate")
    field(DESC, "Set Predefined Rate")
    field(DTYP, "stream")
    field( OUT, "@devkeithley6514.proto setADRate $(PORT) $(A)")
    field(ZRST, "Slow")
    field(ZRVL, "0")
    field(ONST, "Med")
    field(ONVL, "1")
    field(TWST, "Fast")
    field(TWVL, "2")
    field(FLNK, "$(SYS)-$(SUBSYS):$(DEV):GetADRate")
record(mbbi, "$(SYS)-$(SUBSYS):$(DEV):GetADRate")
    field(DESC, "Get Predefined Rate")
    field( INP, "@devkeithley6514.proto getADRate $(PORT) $(A)")
    field(ZRST, "Slow")
    field(ZRVL, "0")
    field(ONST, "Med")
    field(ONVL, "1")
    field(TWST, "Fast")
    field(TWVL, "2")
    field(PINI, "YES")
--- protocol file ---
setADRate {
    out "CURR:NPLC %{6.00|1.00|0.10}";
    @init { out "CURR:NPLC?"; in "%{6.00|1.00|0.10}"; }
getADRate {
    ExtraInput = Ignore;
It works fine if I set only predefined bit in mbbo and mbbi, such as 0, 1, and 2.
  case 1) caput  ECR11-Diag:FC01:SetADRate 3
     returns the following messages:
Warning: enum index value '3' may be too large.
Old : ECR11-Diag:FC01:SetADRate      Slow
CA.Client.Exception...............................................
   Warning: "Channel write request failed"
Context: "op=1, channel=ECR11-Diag:FC01:SetADRate, type=DBR_DOUBLE, count=1, ctx="ECR11-Diag:FC01:SetADRate""
   Source File: ../oldChannelNotify.cpp line 160
New : ECR11-Diag:FC01:SetADRate
   Current Time: Wed Mar 04 2015 07:56:12.932662247
  At this point, the following 4 values are
  ECR11-Diag:FC01:SetADRate.VAL
  ECR11-Diag:FC01:SetADRate.RVAL 0
  ECR11-Diag:FC01:SetADRate.STAT CALC
  ECR11-Diag:FC01:SetADRate.SEVR INVALID
   case 2) caput  ECR11-Diag:FC01:SetADRate -1
New : ECR11-Diag:FC01:SetADRate      Illegal Value
    Current Time: Wed Mar 04 2015 07:56:05.867136097
  ECR11-Diag:FC01:SetADRate.VAL  Illegal Value
  ECR11-Diag:FC01:SetADRate.STAT SOFT
Two behaviors are quite acceptable and reasonable in terms of a client, but the many problems are in the IOC itself. IOC prints a ton of error or warning messages as follows
  Case 1)
2015/03/04 14:07:30.017055 cbLow Value 3 not found in enum set
2015/03/04 14:07:30.017583 cbLow ECR11-Diag:FC01:SetADRate: Formatting value 3 failed 2015/03/04 14:07:30.017610 cbLow ECR11-Diag:FC01:SetADRate: Cannot format value with '%{6.00|1.00|0.10}'
  Case 2)
2015/03/04 14:07:12.854089 cbLow Value 65534 not found in enum set
2015/03/04 14:07:12.854104 cbLow ECR11-Diag:FC01:SetADRate: Formatting value 65534 failed 2015/03/04 14:07:12.854283 cbLow ECR11-Diag:FC01:SetADRate: Cannot format value with '%{6.00|1.00|0.10}'
  Here is my question:
  How to ignore out-of-range index in mbbo or mbbi in both cases?
  Where I have to implement it?
  Han
Jeong Han Lee, Dr.rer.nat.
Accelerator Systems Division
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel  : +82-42-878-8733
fax  : +82-42-878-8799
Re: How to handle out-of-index of MBBO/MBBI? Michael Davidsaver
Prev: Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
Next: Re: error on the IOC shell for asyn driver Vishnu Patel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: error on the IOC shell for asyn driver Mark Rivers
Next: Re: How to handle out-of-index of MBBO/MBBI? Michael Davidsaver
