1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with HDF5 plugin for areaDetector
Date: Thu, 5 Mar 2015 01:15:03 +0000
Hi Mark,
Tried what you suggested. I aligned by forked master with the latest from ADCore (See log below). After a `make clean` and `make` I still get the error. I have also attached a screenshot of the plugin (sorry for the png) to show the settings. Basically from this point on, starting capture to start makes it go boom. I am using the default packages from debian (see below). I couldn’t get the other branch to compile on the head, but haven’t looked fully as to why not.
Stuart
commit bbed9e7b1e0844413078e06806653f2744ce5e60
Author: Stuart B. Wilkins <[email protected]>
Date:   Wed Mar 4 20:04:20 2015 -0500
    Updates for CSX
commit 5a09bfab5bfa48303aef8dfd407be131be205f45
Merge: eeafcbc 4cd14fe
Author: Mark Rivers <[email protected]>
Date:   Wed Mar 4 18:44:29 2015 -0600
    Merge branch 'circ_buff_trigger'
commit eeafcbcb556bbe35ffde736dbf64ed919aff2bfc
Merge: ea0a72e d75877e
Date:   Wed Mar 4 18:42:08 2015 -0600
    Merge pull request #70 from timmmooney/master
    display-file translations 3/3/2015
commit 4cd14fe798b0909ae73d6e6d226e950303ea9c69
Date:   Wed Mar 4 17:11:24 2015 -0600
    Removed duplicate record
ii  hdf5-helpers                          1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - Helper tools
ii  hdf5-tools                            1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - Runtime tools
ii  libhdf4-0                             4.2r4-13                                          amd64        Hierarchical Data Format 4 library -- library package
ii  libhdf4-0-alt                         4.2r4-13                                          amd64        Hierarchical Data Format 4 library -- library package
ii  libhdf5-7                             1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - runtime files - serial version
ii  libhdf5-dev                           1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - development files - serial version
ii  libhdf5-serial-dev                    1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - development files - transitionnal package
ii  python-h5py                           2.0.1-2+b1                                        amd64        h5py is a general-purpose Python interface to hdf5
RE: Problem with HDF5 plugin for areaDetector Mark Rivers
Problem with HDF5 plugin for areaDetector Wilkins, Stuart
Re: Problem with HDF5 plugin for areaDetector Wilkins, Stuart
Prev: acalcout subarray indices jon
Next: Re: How to handle out-of-index of MBBO/MBBI? Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem with HDF5 plugin for areaDetector Mark Rivers
Next: RE: Problem with HDF5 plugin for areaDetector Mark Rivers
