So, here I've found the solution. I add the severity to unused bit
entries (from 3 to 15) as "INVALID". After this, the IOC remains calm
whenever I send to it whatever. Here the db and the test results are:
* DB -----------------------------
record(mbbo, "$(SYS)-$(SUBSYS):$(DEV):SetADRate")
field(DESC, "Set Predefined Rate")
field(DTYP, "stream")
field( OUT, "@devkeithley6514.proto setADRate $(PORT) $(A)")
field(ZRST, "Slow")
field(ZRVL, "0")
field(ONST, "Med")
field(ONVL, "1")
field(TWST, "Fast")
field(TWVL, "2")
field(THSV, "INVALID")
field(FRSV, "INVALID")
field(FVSV, "INVALID")
field(SXSV, "INVALID")
field(SVSV, "INVALID")
field(EISV, "INVALID")
field(NISV, "INVALID")
field(TESV, "INVALID")
field(ELSV, "INVALID")
field(TVSV, "INVALID")
field(TTSV, "INVALID")
field(FTSV, "INVALID")
field(FFSV, "INVALID")
field(IVOA, "Don't drive outputs")
# field(UNSV, "INVALID")
field(FLNK, "$(SYS)-$(SUBSYS):$(DEV):GetADRate")
* Test ------------------
jhlee@kaffee:~/epics/R3.14.12.4/siteApps/keithley6514$ caput
ECR11-Diag:FC01:SetADRate 1 && bash test.sh
Old : ECR11-Diag:FC01:SetADRate
New : ECR11-Diag:FC01:SetADRate Med
ECR11-Diag:FC01:SetADRate.VAL Med
ECR11-Diag:FC01:SetADRate.RVAL 1
ECR11-Diag:FC01:SetADRate.STAT NO_ALARM
ECR11-Diag:FC01:SetADRate.SEVR NO_ALARM
ECR11-Diag:FC01:SetADRate.ACKS INVALID
ECR11-Diag:FC01:SetADRate -1 && bash test.sh
Old : ECR11-Diag:FC01:SetADRate Med
New : ECR11-Diag:FC01:SetADRate Illegal Value
ECR11-Diag:FC01:SetADRate.VAL Illegal Value
ECR11-Diag:FC01:SetADRate.STAT SOFT
ECR11-Diag:FC01:SetADRate.SEVR INVALID
ECR11-Diag:FC01:SetADRate 5 && bash test.sh
Warning: enum index value '5' may be too large.
Old : ECR11-Diag:FC01:SetADRate Illegal Value
ECR11-Diag:FC01:SetADRate.RVAL 0
ECR11-Diag:FC01:SetADRate.STAT STATE
If you have any comments, please let me know.
Han
On 03/05/2015 08:59 AM, Andrew Johnson wrote:
On 03/04/2015 05:48 PM, Jeong Han Lee wrote:
By the way, in the EPICS wiki,
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Common, I see
three possible selections in Invalid Alarm Output Action section are
CONTINUE, NO_OUTPUT, and OUTPUT_IVOV.
IOC returns the following message:
Can't set "ECR11-Diag:FC01:SetADRate.IVOA" to "NO_OUTPUT"
Error at or before ")" in file "db/devkeithley6514.db" line 522
However, Michael and Chris told me to use "Don't drive outputs" and I
found three possible selections such as "Continue normally", "Don't
drive outputs", and "Set output to IVOV" in menuIvoa.dbd. No error
messages I can see in the IOC. I guess the wiki is out-of-date. Am I
correct?
Yes, although the new strings have been in place since at least 1996. I
just fixed the Wiki. Thanks!
- Andrew
Jeong Han Lee, Dr.rer.nat.
Accelerator Systems Division
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel : +82-42-878-8733
fax : +82-42-878-8799
- How to handle out-of-index of MBBO/MBBI? Jeong Han Lee
- Re: How to handle out-of-index of MBBO/MBBI? Michael Davidsaver
- Re: How to handle out-of-index of MBBO/MBBI? Jeong Han Lee
- Re: How to handle out-of-index of MBBO/MBBI? Andrew Johnson
Re: Problem with HDF5 plugin for areaDetector Wilkins, Stuart
RE: Problem with HDF5 plugin for areaDetector Mark Rivers
<2015>
2025
2026
Errors while building medm3.1.9 GONG Yu
<2015>
2025
2026
