1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with HDF5 plugin for areaDetector
To: "Wilkins, Stuart" <[email protected]>
Date: Thu, 5 Mar 2015 02:59:16 +0000
Hi Stuart,
I was able to reproduce your problem.  Your screen shot shows the problem.  You are in "Stream" mode but you have set NumCapture to 0.  Under those conditions it crashed for me with a similar error.  If you are in Stream mode you need to set NumCapture to a positive number, i.e. the number of images you want to save before closing the file.
Please try the following:
- In Stream mode set NumCapture to 5 and then press Capture/Start.  It should save a single file with 5 images.
- Change to Single mode and then press Save to save a single frame.
See if both of these work for you, they do for me.
Admittedly it should not crash under the condition where NumCapture=0, so we will work on that.
This is the error I got:
2015/03/04 20:51:31.465 NDPluginFile:writeFileBase Error writing file, status=3
HDF5-DIAG: Error detected in HDF5 (1.8.7) thread 0:
  #000: H5Dio.c line 245 in H5Dwrite(): file selection+offset not within extent
    major: Dataspace
    minor: Out of range
Sent: Wednesday, March 04, 2015 7:15 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: Problem with HDF5 plugin for areaDetector
Hi Mark,
Tried what you suggested. I aligned by forked master with the latest from ADCore (See log below). After a `make clean` and `make` I still get the error. I have also attached a screenshot of the plugin (sorry for the png) to show the settings. Basically from this point on, starting capture to start makes it go boom. I am using the default packages from debian (see below). I couldn’t get the other branch to compile on the head, but haven’t looked fully as to why not.
Stuart
[cid:CD232CDB-CDF8-486C-B20B-734D3D3846EC]
commit bbed9e7b1e0844413078e06806653f2744ce5e60
Author: Stuart B. Wilkins <[email protected]<mailto:[email protected]>>
Date:   Wed Mar 4 20:04:20 2015 -0500
    Updates for CSX
commit 5a09bfab5bfa48303aef8dfd407be131be205f45
Merge: eeafcbc 4cd14fe
Author: Mark Rivers <[email protected]<mailto:[email protected]>>
Date:   Wed Mar 4 18:44:29 2015 -0600
    Merge branch 'circ_buff_trigger'
commit eeafcbcb556bbe35ffde736dbf64ed919aff2bfc
Merge: ea0a72e d75877e
Date:   Wed Mar 4 18:42:08 2015 -0600
    Merge pull request #70 from timmmooney/master
    display-file translations 3/3/2015
commit 4cd14fe798b0909ae73d6e6d226e950303ea9c69
Date:   Wed Mar 4 17:11:24 2015 -0600
    Removed duplicate record
ii  hdf5-helpers                          1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - Helper tools
ii  hdf5-tools                            1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - Runtime tools
ii  libhdf4-0                             4.2r4-13                                          amd64        Hierarchical Data Format 4 library -- library package
ii  libhdf4-0-alt                         4.2r4-13                                          amd64        Hierarchical Data Format 4 library -- library package
ii  libhdf5-7                             1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - runtime files - serial version
ii  libhdf5-dev                           1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - development files - serial version
ii  libhdf5-serial-dev                    1.8.8-9+b1                                        amd64        Hierarchical Data Format 5 (HDF5) - development files - transitionnal package
ii  python-h5py                           2.0.1-2+b1                                        amd64        h5py is a general-purpose Python interface to hdf5
PNG image
RE: Problem with HDF5 plugin for areaDetector Mark Rivers
Problem with HDF5 plugin for areaDetector Wilkins, Stuart
Re: Problem with HDF5 plugin for areaDetector Wilkins, Stuart
Prev: Re: How to handle out-of-index of MBBO/MBBI? Jeong Han Lee
Next: RE: Is there a way to view the type of flags associated with a link Abadie Lana
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with HDF5 plugin for areaDetector Wilkins, Stuart
Next: RE: Problem with HDF5 plugin for areaDetector Mark Rivers
