1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: StatusCreate class with Throwable
To: [email protected]
Date: Sat, 14 Mar 2015 14:37:10 +0100
Hello all,
I'm trying to create a Status Object in EPICSv4 with JAVA and I'm using Status Factory and StatusCreate class. However, in the documentation of the StatusCreate class says:
	 * Create status.
	 * @param type status type, non-<code>null</code>.
	 * @param message message describing an error, non-<code>null</code>.
* NOTE: Do NOT use <code>throwable.getMessage()</code> as message, since it will be supplied with the <code>cause</code>.
	 * @param cause exception that caused an error. Optional.
	 * @return status instance.
	Status createStatus(StatusType type, String message, Throwable cause);
About creating an status says that parameter Throwable cause it says it's optional but I can't see how it can be optional. And also, if status is OK you should not return the status in a catch excepcion clause, should I? So in that case, status OK how I suppose to have a Throwable object? Then I should use null in this parameter, am I right? Thank you very much for your help.
Yours, Ricardo
Doctorando i2a2
Jefe de Servicio de Instalaciones - CEDEX
Prev: Re: SNL: state change statement in entry block Johnson, Andrew N.
Next: RE: state change statement in entry block Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SNL: state change statement in entry block Benjamin Franksen
Next: Problems running areaDetector to control simulation detector GONG Yu
