1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems running areaDetector to control simulation detector
To: [email protected]
Date: Sun, 15 Mar 2015 17:36:27 +0800 (GMT+08:00)
Hi everyone,
   I come into problems while I was trying to run the areaDetector to control a simulation detector.
   I follow the instuctions of "Using AreaDetector: Lab Handout" on http://www.aps.anl.gov/epics/docs/APS2015.php.
   The areaDetector has been installed in /home/gongyu/areaDetector-master
   I copy it to a new directory /home/gongyu/test_areaDetector/
   I change to the /home/gongyu/test_areaDetector/areaDetector-master/configure/, and edit the file RELEASE_PATHS.Local, and changed the line to
   AREA_DETECTOR= /home/gongyu/test_areaDetector/areaDetector-master
   Changing to the ADCore directory, and issue the following command:
   make -sj clean uninstall
   make -sj
   (I do not know if the option -j is needed, but I follow it)
   Changing to the directory
   /home/gongyu/test_areaDetector/areaDetector-master/ADCore/iocs/simDetectorIOC/iocBoot/iocSimDetector
   Edit st.cmd, change the line:
   epicsEnvSet("PREFIX", "SIM_1:")
   Then, I issue the command:
   medm -x -macro "P=SIM_1:, R=cam1:" simDetector.adl &
   and it shows that
[1] 13437
[gongyu@gongyu iocSimDetector]$
medmInit: Unable to load font widgetDM_4
  Trying default (fixed) instead
medmInit: Unable to load font widgetDM_6
medmInit: Unable to load font widgetDM_8
medmInit: Unable to load font widgetDM_10
medmInit: Unable to load font widgetDM_12
medmInit: Unable to load font widgetDM_14
medmInit: Unable to load font widgetDM_16
medmInit: Unable to load font widgetDM_18
medmInit: Unable to load font widgetDM_20
medmInit: Unable to load font widgetDM_22
medmInit: Unable to load font widgetDM_24
medmInit: Unable to load font widgetDM_30
medmInit: Unable to load font widgetDM_36
medmInit: Unable to load font widgetDM_40
medmInit: Unable to load font widgetDM_48
medmInit: Unable to load font widgetDM_60
MEDM Version 3.1.9: Loading aliased fonts.................
I do not know why it is Unable to load font widgetDM_XX.
I just change to the directory /home/gongyu/ImageJ, double click the icon ImageJ.
(At this time, There is a warning in my os: SELinux is preventing ImageJ from loading /home/gongyu/ImageJ/jre/lib/i386/client/libjvm.so which requires text relocation. I do not know if it will influence the latter processing)
Then, in the directory:
/home/gongyu/test_areaDetector/areaDetector-master/ADCore/iocs/simDetectorIOC/iocBoot/iocSimDetector,
cp envPaths envPaths.linux
then, I issue the command:
../../bin/linux-x86/simDetectorApp st.cmd.linux
There is another problem, the results are listed below:
< envPaths.linux
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iocSimDetector")
epicsEnvSet("TOP","/home/gongyu/test_areaDetector/areaDetector-master/ADCore/iocs/simDetectorIOC")
epicsEnvSet("AREA_DETECTOR","/home/gongyu/test_areaDetector/areaDetector-master")
epicsEnvSet("ADBINARIES","/home/gongyu/test_areaDetector/areaDetector-master/ADBinaries")
epicsEnvSet("ADCORE","/home/gongyu/test_areaDetector/areaDetector-master/ADCore")
< st.cmd
# Must have loaded envPaths via st.cmd.linux or st.cmd.win32
errlogInit(20000)
dbLoadDatabase("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/iocs/simDetectorIOC/dbd/simDetectorApp.dbd")
simDetectorApp_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("PORT",   "SIM1")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "1024")
epicsEnvSet("YSIZE",  "1024")
epicsEnvSet("NCHANS", "2048")
# The EPICS environment variable EPICS_CA_MAX_ARRAY_BYTES needs to be set to a value at least as large
# as the largest image that the standard arrays plugin will send.
# That vlaue is $(XSIZE) * $(YSIZE) * sizeof(FTVL data type) for the FTVL used when loading the NDStdArrays.template file.
# The variable can be set in the environment before running the IOC or it can be set here.
# It is often convenient to set it in the environment outside the IOC to the largest array any client
# or server will need.  For example 10000000 (ten million) bytes may be enough.
# If it is set here then remember to also set it outside the IOC for any CA clients that need to access the waveform record.
# Do not set EPICS_CA_MAX_ARRAY_BYTES to a value much larger than that required, because EPICS Channel Access actually
# allocates arrays of this size every time it needs a buffer larger than 16K.
# Uncomment the following line to set it in the IOC.
#epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES", "10000000")
# Create a simDetector driver
# simDetectorConfig(const char *portName, int maxSizeX, int maxSizeY, int dataType,
#                   int maxBuffers, int maxMemory, int priority, int stackSize)
simDetectorConfig("SIM1", 1024, 1024, 1, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/ADBase.template",     "P=SIM_1:,R=cam1:,PORT=SIM1,ADDR=0,TIMEOUT=1")
# To have the rate calculation use a non-zero smoothing factor use the following line
#dbLoadRecords("$(ADCORE)/db/ADBase.template",     "P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1,RATE_SMOOTH=0.2")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/simDetector.template","P=SIM_1:,R=cam1:,PORT=SIM1,ADDR=0,TIMEOUT=1")
# Create a second simDetector driver
simDetectorConfig("SIM2", 300, 200, 1, 50, 50000000)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/ADBase.template",     "P=SIM_1:,R=cam2:,PORT=SIM2,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/simDetector.template","P=SIM_1:,R=cam2:,PORT=SIM2,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin, set it to get data from first simDetector driver.
NDStdArraysConfigure("Image1", 3, 0, "SIM1", 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
# This creates a waveform large enough for 1024x1024x3 (e.g. RGB color) arrays.
# This waveform only allows transporting 8-bit images
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDStdArrays.template", "P=SIM_1:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int8,FTVL=UCHAR,NELEMENTS=3145728")
# This waveform only allows transporting 16-bit images
#dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int16,FTVL=USHORT,NELEMENTS=3145728")
# This waveform allows transporting 32-bit images
#dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=3145728")
# Create a standard arrays plugin, set it to get data from second simDetector driver.
NDStdArraysConfigure("Image2", 1, 0, "SIM2", 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=image2:,PORT=Image2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM2,NDARRAY_ADDR=0")
# This creates a waveform large enough for 640x480x3 (e.g. RGB color) arrays.
# This waveform allows transporting 64-bit images, so it can handle any detector data type at the expense of more memory and bandwidth
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDStdArrays.template", "P=SIM_1:,R=image2:,PORT=Image2,ADDR=0,TIMEOUT=1,TYPE=Float64,FTVL=DOUBLE,NELEMENTS=921600")
# Load all other plugins using commonPlugins.cmd
< /home/gongyu/test_areaDetector/areaDetector-master/ADCore/iocBoot/commonPlugins.cmd
# Create a netCDF file saving plugin.
NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "SIM1", 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFile.template",      "P=SIM_1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFileNetCDF.template","P=SIM_1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 20, 0, "SIM1", 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFile.template",      "P=SIM_1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFileTIFF.template",  "P=SIM_1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 20, 0, "SIM1", 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFile.template",      "P=SIM_1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFileJPEG.template",  "P=SIM_1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1")
# Create a NeXus file saving plugin
NDFileNexusConfigure("FileNexus1", 20, 0, "SIM1", 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFile.template",      "P=SIM_1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFileNexus.template", "P=SIM_1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 20, 0, "SIM1", 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFile.template",      "P=SIM_1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFileHDF5.template",  "P=SIM_1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1")
# Create a Magick file saving plugin
NDFileMagickConfigure("FileMagick1", 20, 0, "SIM1", 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFile.template",      "P=SIM_1:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDFileMagick.template","P=SIM_1:,R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 20, 0, "SIM1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDROI.template",       "P=SIM_1:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1")
NDROIConfigure("ROI2", 20, 0, "SIM1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDROI.template",       "P=SIM_1:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1")
NDROIConfigure("ROI3", 20, 0, "SIM1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDROI.template",       "P=SIM_1:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1")
NDROIConfigure("ROI4", 20, 0, "SIM1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDROI.template",       "P=SIM_1:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1")
# Create a processing plugin
NDProcessConfigure("PROC1", 20, 0, "SIM1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDProcess.template",   "P=SIM_1:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "SIM1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDStats.template",     "P=SIM_1:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048")
NDStatsConfigure("STATS2", 20, 0, "ROI1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI2,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDStats.template",     "P=SIM_1:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048")
NDStatsConfigure("STATS3", 20, 0, "ROI2", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI3,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDStats.template",     "P=SIM_1:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048")
NDStatsConfigure("STATS4", 20, 0, "ROI3", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ROI4,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDStats.template",     "P=SIM_1:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048")
NDStatsConfigure("STATS5", 20, 0, "ROI4", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDStats.template",     "P=SIM_1:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1024,YSIZE=1024,NCHANS=2048")
# Create a transform plugin
NDTransformConfigure("TRANS1", 20, 0, "SIM1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDTransform.template", "P=SIM_1:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 20, 0, "SIM1", 0, 8, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template","P=SIM_1:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDOverlay.template",   "P=SIM_1:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDOverlayN.template","P=SIM_1:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=SIM_1:ROI1:MinX_RBV,YPOS=SIM_1:ROI1:MinY_RBV,XSIZE=SIM_1:ROI1:SizeX_RBV,YSIZE=SIM_1:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDOverlayN.template","P=SIM_1:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=SIM_1:ROI2:MinX_RBV,YPOS=SIM_1:ROI2:MinY_RBV,XSIZE=SIM_1:ROI2:SizeX_RBV,YSIZE=SIM_1:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDOverlayN.template","P=SIM_1:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=SIM_1:ROI3:MinX_RBV,YPOS=SIM_1:ROI3:MinY_RBV,XSIZE=SIM_1:ROI3:SizeX_RBV,YSIZE=SIM_1:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDOverlayN.template","P=SIM_1:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=SIM_1:ROI4:MinX_RBV,YPOS=SIM_1:ROI4:MinY_RBV,XSIZE=SIM_1:ROI4:SizeX_RBV,YSIZE=SIM_1:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDOverlayN.template","P=SIM_1:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDOverlayN.template","P=SIM_1:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDOverlayN.template","P=SIM_1:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDOverlayN.template","P=SIM_1:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 20, 0, "SIM1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template",   "P=SIM_1:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDColorConvert.template", "P=SIM_1:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1")
NDColorConvertConfigure("CC2", 20, 0, "SIM1", 0, 0, 0)
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDPluginBase.template",   "P=SIM_1:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SIM1,NDARRAY_ADDR=0")
dbLoadRecords("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/db/NDColorConvert.template", "P=SIM_1:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1")
# Load scan records
macLib: macro SSCAN is undefined (expanding string dbLoadRecords("$(SSCAN)/sscanApp/Db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10"))
# Load sseq record for acquisition sequence
macLib: macro CALC is undefined (expanding string dbLoadRecords("$(CALC)/calcApp/Db/yySseq.db", "P=$(PREFIX), S=AcquireSequence"))
set_requestfile_path("./")
set_requestfile_path("/home/gongyu/test_areaDetector/areaDetector-master/ADCore/ADApp/Db")
macLib: macro CALC is undefined (expanding string set_requestfile_path("$(CALC)/calcApp/Db"))
macLib: macro SSCAN is undefined (expanding string set_requestfile_path("$(SSCAN)/sscanApp/Db"))
set_savefile_path("./autosave")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("SIM_1:")
macLib: macro AUTOSAVE is undefined (expanding string dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=$(PREFIX)"))
#asynSetTraceIOMask("$(PORT)",0,2)
#asynSetTraceMask("$(PORT)",0,255)
#asynSetTraceIOMask("FileNetCDF",0,2)
#asynSetTraceMask("FileNetCDF",0,255)
#asynSetTraceMask("FileNexus",0,255)
#asynSetTraceMask("SIM2",0,255)
iocInit()
Starting iocInit
## EPICS R3.14.12.4 $Date: Mon 2013-12-16 15:51:45 -0600$
## EPICS Base built Jan 27 2015
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore (v5.1): entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P=SIM_1:")
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
save_restore:readReqFile: unable to open file scan_settings.req. Exiting.
epics> save_restore: Can't connect to all status PV(s)
auto_settings.sav: 677 of 677 PV's connected
save_restore: Can't connect to status PV(s) for list 'auto_settings.sav'
I do not know what it means and how to solve this problem.
The areaDetector and medm are installed in the same computer (i.e. in my laptop. medm is a client, and areaDetector is a server, I do not know if my understanding is correct?).
I did not set the The EPICS_CA_ADDR_LIST and EPICS_CA_AUTO_ADDR_LIST variables (I don't know how to set these variables when areaDetector and medm are in the same computer?).
EPICS_CA_MAX_ARRAY_BYTES is set to 4154000 (I don't know how many pixels and dynamic range of the simulation detector)
EPICS_DISPLAY_PATH is set to /home/gongyu/EPICS/adls
ImageJ is in /home/gongyu/ImageJ
My letter is lengthy with so many questions, I hope someone could help me. Thank you in advance.
GongYu
RE: Problems running areaDetector to control simulation detector Mooney, Tim M.
RE: Problems running areaDetector to control simulation detector Mark Rivers
Prev: Re: SNL: state change statement in entry block Benjamin Franksen
Next: RE: Problems running areaDetector to control simulation detector Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: StatusCreate class with Throwable Ricardo Herrero
