1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pyepics not updating pv.enum_strs after connection
To: Dirk Zimoch <[email protected]>, [email protected]
Date: Wed, 25 Mar 2015 10:16:31 -0700
On Wed, Mar 25 2015, Dirk Zimoch <[email protected]> wrote:
> I quickly checked medm. At reconnect, it does update its channel infos
> (for the info dialog?) But it does not update the element count or the
> data type. I wonder what happens when an array of 10 ints is changed to
> an array of 20 strings after reboot. Need to try...
Yes, MEDM is one of the main culprits for us.  The enum drop-down menus
become stale, which is pretty bad in this case since the menu continues
to display the old string list, but MEDM sends the underlying int, which
in turn maps to a new value on the server.  We've had many occasions
where the operator has sent bad requests back to the server because of
this.
jamie.
Attachment: signature.asc
Description: PGP signature
pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Re: pyepics not updating pv.enum_strs after connection Matt Newville
Re: pyepics not updating pv.enum_strs after connection Dirk Zimoch
Re: pyepics not updating pv.enum_strs after connection Andrew Johnson
Prev: Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Next: Re: pyepics not updating pv.enum_strs after connection Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pyepics not updating pv.enum_strs after connection Dirk Zimoch
Next: Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
