1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pyepics not updating pv.enum_strs after connection
Date: Wed, 25 Mar 2015 13:25:46 -0500
Hi Andrew,
On Wed, Mar 25, 2015 at 11:21 AM, Andrew Johnson <[email protected]> wrote:
On 03/25/2015 10:55 AM, Dirk Zimoch wrote:
> On 25.03.2015 04:46, Matt Newville wrote:
>> Yes, I think this idea of getting the ctrl variables in the connection
>> callback is a good idea, and will allow more straightforward code  As it
>> is, a pyepics.PV is already expected to be a "rich" object, even if
>> sacrificing ultimate performance, and is normally expected to have the
>> ctrl variables.   So, I think it's reasonable to have this getting of
>> ctrl variables as the default.    I'll add that.
> This is generally a good idea for every ca client. After a reboot,
> anything may have changed: Enum strings, limits, units, precision, array
> size, even record type (and thus data type).
Recent versions of Base (3.14.11 on) have a CA monitor event type
DBE_PROPERTY which was intended for monitoring changes to metadata like
the ctrl variables. 3.14 IOCs don't send out many property events (and
the PV Gateway doesn't support property subscriptions yet either), but
as 3.15 and later IOCs come in they make the case for using this quite a
bit more compelling. I would encourage CA client developers to read the
tech-talk threads discussing DBE_PROPERTY first though, there are a few
gotchas.
Is it reasonable to simply change the event subscription mask to include DBE_PROPERTY by default?  Will doing so work (in the sense of "not fail"), even though only getting VALUE, LOG, and ALARM events) for older iocs and through gateways?  If so, that's an easy change to make.
Cheers,
--Matt Newville
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: pyepics not updating pv.enum_strs after connection Andrew Johnson
Re: pyepics not updating pv.enum_strs after connection Michael Davidsaver
pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Re: pyepics not updating pv.enum_strs after connection Matt Newville
Re: pyepics not updating pv.enum_strs after connection Dirk Zimoch
Prev: Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Next: Re: pyepics not updating pv.enum_strs after connection Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
