Hi All.
For me it's unable to obtain context information about the PV in
c++ before a new value is received
Attached:
Please see the record, sourcecode and output below.
Problem:
getDisplayLimitLower() returns 0, while it should return -10.
If I put pv->getDisplayLimitLower() in the (slot-)method it
returns the right value.
Question:
How to obtain the DRVH, DRVL, and PREC during setup? Where can I
get documentation, how to do this right? Any tutorial available?
How to deal with this problem?
record:
record(ao, "testdevice1:outCur") {
field(PREC, "3")
field(EGU, "A")
field(DRVH, "10")
field(DRVL, "-10")
field(HOPR, "10")
field(LOPR, "-10")
code:
Generator::Generator()
test();
sendSignal( "2" );
void Generator::test()
pv = new QEString( "testdevice1:outCur", this, new
QEStringFormatting, 0, new UserMessage );
pv->subscribe();
QObject::connect( pv, SIGNAL( stringChanged( const
QString&, QCaAlarmInfo&, QCaDateTime&, const unsigned
int & ) ), this, SLOT( slotPvStringChanged( const QString&
QObject::connect( this, SIGNAL( signalWritePv( const
QString& ) ), pv, SLOT( writeString( const QString& ) ) );
std::cerr << "LOPR=" <<
pv->getDisplayLimitLower() << std::endl;
std::cerr << "HOPR=" <<
pv->getDisplayLimitUpper() << std::endl;
std::cerr << "PREC=" << pv->getPrecision()
<< std::endl;
void Generator::slotPvStringChanged( const QString& value
// here pv->getDisplayLimitLower() returns -10
std::cerr << "getting " << value.toStdString()
<< std::endl;
void Generator::sendSignal( const QString& value )
emit signalWritePv( value );
output:
LOPR=0
HOPR=0
PREC=0
getting -3.140 A
getting -3.140 A
Best regards
Thomas Schösser
Dipl. Phys.
Thomas Schösser
Raum 110
Institut für Kernphysik
TU Darmstadt
Schloßgartenstraße 9
64289 Darmstadt
Tel.: +49 6151 16 76955
Re: IOC implementation by JAVA/Python Jameson Graef Rollins
Re: support for DTM-151? Rod Nussbaumer
<2015>
2025
2026
Re: building base-3.15.1: perl -typemap Andrew Johnson
EPICSv4 and pvAccess to an IOC Emmanuel Mayssat
<2015>
2025
2026
ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
