1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aravisGigEApp and glib
To: Mazanec Tomáš <[email protected]>
Cc: "Specht, Eliot D." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 7 Apr 2015 14:47:25 +0000
What version of the top-level areaDetector and aravisGigE are you using? The latest version defines paths for glib in areaDetector/configure/EXAMPLE_CONFIG_SITE.local
The message about .a vs.so is just because it did not find either one.
Sent from my iPhone
On Apr 7, 2015, at 9:30 AM, Mazanec Tomáš <[email protected]<mailto:[email protected]>> wrote:
I don't have synApps 5.8, however in  standalone "aravisGigE-0-1-15dls2", there is GLIBPREFIX option in configure/RELEASE,
then aravisGigEApp/src/Makefile defines USR_INCLUDES and USR_LIBS based on that.
I guess , try to match these with your RHEL.
Other option is to use USR_SYS_LIBS+=glib-2.0 instead.
By default, linker should accept both library formats (.so , .a).
Tomas
Od: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] za uživatele Specht, Eliot D. [[email protected]<mailto:[email protected]>]
Odesláno: 7. dubna 2015 15:39
Komu: [email protected]<mailto:[email protected]>
Předmět: aravisGigEApp and glib
I’m trying to use aravisGigEApp on a RHEL7 linux system to display and capture video images. When I run “make” in aravisGigEApp/src, I get an error which looks like I’m missing libglib-2.0.a (see below). I have /usr/lib64/libglib-2.0.so, but I seem to need the glib2-static package, which is not available for RHEL7. Is there a fix for this, or should I fall back to RHEL6?
[root@video src]# make
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[1]: Entering directory `/opt/epics/synApps_5_8/support/aravisGigE-0-3-5dls5/aravisGigEApp/src/O.linux-x86_64'
make[1]: *** No rule to make target `../../../lib/linux-x86_64/libglib-2.0.a', needed by `libaravisCamera.so'.  Stop.
make[1]: Leaving directory `/opt/epics/synApps_5_8/support/aravisGigE-0-3-5dls5/aravisGigEApp/src/O.linux-x86_64'
make: *** [install.linux-x86_64] Error 2
[root@video src]#
Eliot Specht                        Voice: (865)574-7682
Oak Ridge National Laboratory       FAX:   (865)574-4913
P.O. Box 2008, MS 6064
Oak Ridge, TN 37831-6064
Re: aravisGigEApp and glib Mark Rivers
aravisGigEApp and glib Specht, Eliot D.
RE: aravisGigEApp and glib Mazanec Tomáš
Prev: Re: Stream device problem with redirection in @mismatch ruzickaj
Next: Re: aravisGigEApp and glib Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: aravisGigEApp and glib Mazanec Tomáš
