1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: aravisGigEApp and glib
To: Mazanec Tomáš <[email protected]>
Cc: "Specht, Eliot D." <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 7 Apr 2015 16:02:27 +0000
Sorry, the glib paths are actually defined in EXAMPLE_CONFIG_SITE.local.linux-x86_64.
Sent from my iPhone
> On Apr 7, 2015, at 10:26 AM, Mark Rivers <[email protected]> wrote:
> What version of the top-level areaDetector and aravisGigE are you using? The latest version defines paths for glib in areaDetector/configure/EXAMPLE_CONFIG_SITE.local
> The message about .a vs.so is just because it did not find either one.
> Mark
> Sent from my iPhone
> On Apr 7, 2015, at 9:30 AM, Mazanec Tomáš <[email protected]<mailto:[email protected]>> wrote:
> I don't have synApps 5.8, however in  standalone "aravisGigE-0-1-15dls2", there is GLIBPREFIX option in configure/RELEASE,
> then aravisGigEApp/src/Makefile defines USR_INCLUDES and USR_LIBS based on that.
> I guess , try to match these with your RHEL.
> Other option is to use USR_SYS_LIBS+=glib-2.0 instead.
> By default, linker should accept both library formats (.so , .a).
> Tomas
> ________________________________
> Od: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] za uživatele Specht, Eliot D. [[email protected]<mailto:[email protected]>]
> Odesláno: 7. dubna 2015 15:39
> Komu: [email protected]<mailto:[email protected]>
> Předmět: aravisGigEApp and glib
> I’m trying to use aravisGigEApp on a RHEL7 linux system to display and capture video images. When I run “make” in aravisGigEApp/src, I get an error which looks like I’m missing libglib-2.0.a (see below). I have /usr/lib64/libglib-2.0.so, but I seem to need the glib2-static package, which is not available for RHEL7. Is there a fix for this, or should I fall back to RHEL6?
> [root@video src]# make
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
> make[1]: Entering directory `/opt/epics/synApps_5_8/support/aravisGigE-0-3-5dls5/aravisGigEApp/src/O.linux-x86_64'
> make[1]: *** No rule to make target `../../../lib/linux-x86_64/libglib-2.0.a', needed by `libaravisCamera.so'.  Stop.
> make[1]: Leaving directory `/opt/epics/synApps_5_8/support/aravisGigE-0-3-5dls5/aravisGigEApp/src/O.linux-x86_64'
> make: *** [install.linux-x86_64] Error 2
> [root@video src]#
> Eliot Specht                        Voice: (865)574-7682
> Oak Ridge National Laboratory       FAX:   (865)574-4913
> P.O. Box 2008, MS 6064
> Oak Ridge, TN 37831-6064
aravisGigEApp and glib Specht, Eliot D.
RE: aravisGigEApp and glib Mazanec Tomáš
Re: aravisGigEApp and glib Mark Rivers
Prev: Re: aravisGigEApp and glib Mark Rivers
Next: send a file to IOC [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
