1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: how NOT to update the record
To: Tasaddaq Khan <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 10 Jul 2015 09:41:16 +0200
Hi Tasaddaq,
You have explicitly configured your record d to do "A+1", with A fetched from record c, and you say that c should be zero if you set b to 0.
The value that record b puts into the VAL field of record d will be overwritten when d processes, fetching A from record c and calculating "A+1".
If you want d to use its own last VAL, d.CALC should be "VAL+1".
~Ralph
On 10/07/2015 07:59, Tasaddaq Khan wrote:
Hi Tim Mooney
The problem is still same and this does not solve the problem. Even with this value of record 'd' does not update.
Is there any other way to solve the problem in EPICS?
tasaddaq
On Thu, Jul 9, 2015 at 7:56 PM, Mooney, Tim M. <[email protected]> wrote:
Hi Tasaddaq,
One way to do that is like this:
record (calcout, "c"){
field(SCAN, "1 second")
field(INPA, "c")
field(INPB,"b")
field(INPC,"1")
field(CALC,"d:=a+c;b")
field(OCAL,"d")
field(OOPT, "When Non-zero")
field(DOPT, "Use OCAL")
field(OUT,"d PP")
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Thursday, July 09, 2015 2:11 AM
To: Mooney, Tim M.
Hi Tim
I changed my program and use the OOPT field in record c, but the result is same. It sets the value c=0 when b=0 and record d keeps the last value that is fine, but when I again put b=1, it starts from the starting point but not from the last value it keeps which I do not want. I want that my record d keeps the last value when b=0 and starts from this value when I again put the b=1.
record (bi,"b"){
field(FLNK, "c")
field(INPA, "c")
field(INPB,"b")
field(INPC,"1")
field(CALC,"B=1?A+C:0")
field(OUT,"d PP")
record(calcout, "d"){
field(INPA, "c")
field(INPB,"1")
field(CALC,"A+B^2")
regards,
tasaddaq
On Thu, Jul 9, 2015 at 3:48 AM, Mooney, Tim M. <[email protected]> wrote:
Hi Tasaddaq,
You can use the OOPT field to specify when the output link should be executed.  c.OOPT="When Non-zero"
From: [email protected] [[email protected]] on behalf of Tasaddaq Khan [[email protected]]
Sent: Wednesday, July 08, 2015 1:59 PM
To: [email protected]
Subject: how NOT to update the record
Dear all
I have three records, when the value in the record "b" is "1" the value in the record c is calculated and the record d is updated as well. Upto this the things are working fine. But I want one more thing that when the b=0, the value of record "c" should become the zero (that is happening) but it should not send the value zero to the record d means at b=0 record c should be updated but it should not update the record d. I want to keep the last value of record d so that when b=1 again then record d should start from the last value that it will hold. Please tell me how to do this?
record (bi,"b"){
field(FLNK, "c")
field(INPA, "c")
field(INPB,"b")
field(INPC,"1")
field(OUT,"d PP")
field(INPA, "c")
field(INPB,"1")
field(CALC,"A+B")
regards,
Tasaddaq
how NOT to update the record Tasaddaq Khan
RE: how NOT to update the record Mooney, Tim M.
Re: how NOT to update the record Tasaddaq Khan
Prev: Re: how NOT to update the record Tasaddaq Khan
Next: Driver for ADAM 4017 D2E John . Holt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: how NOT to update the record Ralph Lange
