1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope
To: <[email protected]>
Date: Wed, 12 Aug 2015 07:27:17 -0500
Could you please send me the output of the "make configure" step, as well as the contents of pvaPy/configure/CONFIG_SITE.local file?
Sinisa
On 08/12/2015 01:08 AM, Williams Jr., Ernest L. wrote:
I am working with EPICS V4 and would like to build the python support (i.e. "pvaPy")
HOST = RHEL5 32-bit,  linux-x86
Indeed, I have configured/built the necessary dependent external packages
(1) Boost  ==>  1.58.0
(2) Python ==> 2.7.4
The EPICS V4 release ==> base-cpp-R4-4-0-pre2
The EPICS BASE V3 release ==> base-R3-14-12
pvaPy"
All of the V4 modules build nicely, except that I have the following problem with "pvaPy"
Any help or solutions, appreciated:
../RpcClient.cpp:82: error: 'response' was not declared in this scope
======================= Compile Error Below ============================================
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -MMD -g -I/afs/slac/g/lcls/package/boost/1.58.0/linux-x86/include -I//afs/slac/g/lcls/package/python/current/include/python2.7 -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include/os/Linux -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include  -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/include  -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/include       ../RpcClient.cpp
../RpcClient.cpp: In static member function 'static std::tr1::shared_ptr<epics::pvAccess::RPCClient> RpcClient::createRpcClient(const std::string&, const epics::pvData::PVStructurePtr&, double)':
../RpcClient.cpp:53: warning: no return statement in function returning non-void
../RpcClient.cpp: In member function 'virtual std::tr1::shared_ptr<epics::pvData::PVStructure> RpcClient::request(const epics::pvData::PVStructurePtr&, double)':
make[1]: *** [RpcClient.o] Error 1
make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-cpp-R4-4-0-pre2/pvaPy/src/pvaccess/O.linux-x86'
make: *** [install.linux-x86] Error 2
Sinisa Veseli
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]
(630)252-9182
RE: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Williams Jr., Ernest L.
Prev: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Williams Jr., Ernest L.
Next: RE: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Williams Jr., Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
