From: [email protected] [[email protected]] on behalf of Sinisa Veseli [[email protected]]
Sent: Wednesday, August 12, 2015 5:27 AM
To: [email protected]
Subject: Re: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope
Could you please send me the output of the "make configure" step, as
well as the contents of pvaPy/configure/CONFIG_SITE.local file?
I created "CONFIG_SITE.local" and "RELEASE.local" manually.
The dependent packages required by pvaPy are installed from source in our environment.
We are not using a linux package manager for "boost" and "python"
*************** Output of make configure ********************************************************
[ernesto@lcls-dev2 pvaPy]$ make configure
cd tools/autoconf && ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... none
checking for python... /afs/slac/g/lcls/package/python/current/bin/python
checking for a version of Python >= '2.1.0'... yes
checking for a version of Python >=2.6... yes
checking for the distutils Python package... yes
checking for Python include path... -I/afs/slac/g/lcls/package/python/current/include/python2.7
checking for Python library path... -L/afs/slac/g/lcls/package/python/Python-2.7.4/lib -lpython2.7
checking for Python site-packages path... /afs/slac/g/lcls/package/python/current/lib/python2.7/site-packages
checking python extra libraries... -lpthread -ldl -lutil
checking python extra linking flags... -Xlinker -export-dynamic
checking consistency of all components of python development environment... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... none
checking for boostlib >= 1.40... configure: We could not detect the boost libraries (version 1.40 or higher). If you have a staged boost library (still not installed) please specify $BOOST_ROOT in your environment and do not give a PATH to --with-boost option. If you are sure you have boost installed, then check your version number looking in <boost/version.hpp>. See http://randspringer.de/boost for more documentation.
configure: error: required Boost library version >= 1.40.
make: *** [configure] Error 1
************** Output of CONFIG_SITE.local ****************************************************************************
[ernesto@lcls-dev2 configure]$ more CONFIG_SITE.local
PACKAGE_TOP=/afs/slac/g/lcls/package
PYTHON_TOP=$(PACKAGE)/python/current
BOOST_DIR=$(PACKAGE)/boost/1.58.0/linux-x86
EPICS_HOST_ARCH=linux-x86
BOOST_PYTHON_LIB=boost_python
PVA_PY_CPPFLAGS=-I$(BOOST_DIR)/include -I$(PYTHON_TOP)/include/python2.7
PVA_PY_LDFLAGS=-L$(BOOST_DIR)/lib -L$(PYTHON_TOP)/lib -lpython2.7
Cheers,
Ernest
Sinisa
On 08/12/2015 01:08 AM, Williams Jr., Ernest L. wrote:
> Hi,
> I am working with EPICS V4 and would like to build the python support (i.e. "pvaPy")
> HOST = RHEL5 32-bit, linux-x86
> Indeed, I have configured/built the necessary dependent external packages
> (1) Boost ==> 1.58.0
> (2) Python ==> 2.7.4
> The EPICS V4 release ==> base-cpp-R4-4-0-pre2
> The EPICS BASE V3 release ==> base-R3-14-12
> pvaPy"
> All of the V4 modules build nicely, except that I have the following problem with "pvaPy"
> Any help or solutions, appreciated:
> ../RpcClient.cpp:82: error: 'response' was not declared in this scope
> ======================= Compile Error Below ============================================
> /usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m32 -g -fPIC -MMD -g -I/afs/slac/g/lcls/package/boost/1.58.0/linux-x86/include -I//afs/slac/g/lcls/package/python/current/include/python2.7 -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include/os/Linux -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/include -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/include ../RpcClient.cpp
> ../RpcClient.cpp: In static member function 'static std::tr1::shared_ptr<epics::pvAccess::RPCClient> RpcClient::createRpcClient(const std::string&, const epics::pvData::PVStructurePtr&, double)':
> ../RpcClient.cpp:53: warning: no return statement in function returning non-void
> ../RpcClient.cpp: In member function 'virtual std::tr1::shared_ptr<epics::pvData::PVStructure> RpcClient::request(const epics::pvData::PVStructurePtr&, double)':
> make[1]: *** [RpcClient.o] Error 1
> make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-cpp-R4-4-0-pre2/pvaPy/src/pvaccess/O.linux-x86'
> make: *** [install.linux-x86] Error 2
Sinisa Veseli
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]
(630)252-9182
- Re: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Sinisa Veseli
- Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Williams Jr., Ernest L.
<2015>
2025
2026
<2015>
2025
2026
