1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope
To: "Williams Jr., Ernest L." <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 12 Aug 2015 10:26:16 -0500
Hi Ernest,
Good luck with testing, and if you find any issues, please let me know.
Sinisa
On 08/12/2015 10:01 AM, Williams Jr., Ernest L. wrote:
Hi Sinisa,
Thanks for your help.
By the way,  using CONFIG_SITE.local does work.
I had a typo in there :(
So, no need to modify the source Makefile.
=== My CONFIG_SITE.local ==================================================
PACKAGE_AREA=/afs/slac/g/lcls/package
PYTHON_DIR=$(PACKAGE_AREA)/python/current
BOOST_DIR=$(PACKAGE_AREA)/boost/1.58.0/linux-x86
EPICS_HOST_ARCH=linux-x86
BOOST_PYTHON_LIB=boost_python
PVA_PY_CPPFLAGS=-DPVA_API_VERSION=440 -DPVA_RPC_API_VERSION=440 \
  -I$(BOOST_DIR)/include -I$(PYTHON_DIR)/include/python2.7
PVA_PY_LDFLAGS=-L$(BOOST_DIR)/lib -L$(PYTHON_DIR)/lib -lpython2.7
Now, we start testing :)
Cheers,
Ernest
Sent: Wednesday, August 12, 2015 7:27 AM
To: Sinisa Veseli; [email protected]
Cc: Williams Jr., Ernest L.
Subject: RE: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope
Sent: Wednesday, August 12, 2015 6:51 AM
To: Williams Jr., Ernest L.; [email protected]
Ahh, ok. In this case, you probably used README file example, which
seems to be a bit out of date.
Could you try adding variables below in your CONFIG_SITE.local file, and
let me know what happens.
Sinisa
PVA_API_VERSION=440
-I$(BOOST_DIR)/include -I$(PYTHON_TOP)/include/python2.7
Sure, but there was no change.
Actually, I had to add your changes to the source Makefile
that is  "<....>/base-cpp-R4-4-0-pre2/pvaPy/src/pvaccess/Makefile"
Looks like "CONFIG_SITE.local" does not get referenced by the Makefile.
So, I added the following to the Makefile and all is well now :)
====== src/pvaccess/Makefile   snippet =====================
BOOST_DIR=/afs/slac/g/lcls/package/boost/1.58.0/linux-x86
PYTHON_DIR=/afs/slac/g/lcls/package/python/current
LOADABLE_LIBRARY_HOST += pvaccess
LOADABLE_SHRLIB_PREFIX =
#PROD_HOST_linux-x86_64 += testClient
PROD_HOST += $(PROD_HOST_$(T_A))
PVA_API_VERSION=440
CXXFLAGS += $(PVA_PY_CPPFLAGS)
CXXFLAGS += -g -I$(BOOST_DIR)/include -I/$(PYTHON_DIR)/include/python2.7
LDFLAGS += $(PVA_PY_LDFLAGS)
Compile is now successful:
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -MMD -DPVA_API_VERSION=440 -DPVA_RPC_API_VERSION=440 -g -I/afs/slac/g/lcls/package/boost/1.58.0/linux-x86/include -I//afs/slac/g/lcls/package/python/current/include/python2.7 -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include/os/Linux -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include  -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/include  -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/include       ../StringUtility.cpp
/usr/bin/g++ -o pvaccess.so -shared -fPIC -Wl,-hpvaccess.so -L/afs/slac/g/lcls/epics/base/base-R3-14-12/lib/linux-x86 -L/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/lib/linux-x86 -L/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/lib/linux-x86 -Wl,-rpath,/afs/slac/g/lcls/epics/base/base-R3-14-12/lib/linux-x86 -Wl,-rpath,/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/lib/linux-x86 -Wl,-rpath,/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/lib/linux-x86       -m32        -L/afs/slac/g/lcls/package/boost/1.58.0/linux-x86/lib -L/python/current/lib -lpython2.7        pvaccess.o CaClient.o Channel.o ChannelGetRequesterImpl.o ChannelMonitorRequesterImpl.o ChannelPutRequesterImpl.o ChannelRequesterImpl.o ChannelTimeout.o FieldNotFound.o GetFieldRequesterImpl.o InvalidArgument.o InvalidDataType.o InvalidRequest.o InvalidState.o NtTable.o NtType.o ObjectNotFound.o PvaClient.o PvaException.o PvaExceptionTranslator.o PvaPyLogger.o PvA!
larm.o PvBoolean.o PvByte.o PvDouble.o PvFloat.o PvInt.o PvLong.o PvObject.o PvProvider.o PvScalar.o PvScalarArray.o PvShort.o PvString.o PvTimeStamp.o PvUByte.o PvUInt.o PvULong.o PvUShort.o PvUtility.o PyGilManager.o PyPvDataUtility.o PyUtility.o RequesterImpl.o RpcClient.o RpcServiceImpl.o RpcServer.o RpcTimeout.o StringUtility.o    -lpvData -lpvAccess -lCom  -lboost_python -lpthread   -lreadline -lncurses -lm -lrt -ldl -lgcc
Installing loadable shared library ../../../lib/linux-x86/pvaccess.so
make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-cpp-R4-4-0-pre2/pvaPy/src/pvaccess/O.linux-x86'
Cheers,
Ernest
From: [email protected] [[email protected]] on behalf of Sinisa Veseli [[email protected]]
Sent: Wednesday, August 12, 2015 5:27 AM
To: [email protected]
Could you please send me the output of the "make configure" step, as
well as the contents of pvaPy/configure/CONFIG_SITE.local file?
I created "CONFIG_SITE.local" and "RELEASE.local" manually.
The dependent packages required by pvaPy are installed from source in our environment.
We are not using a linux package manager for "boost" and "python"
*************** Output of make configure ********************************************************
[ernesto@lcls-dev2 pvaPy]$ make configure
cd tools/autoconf && ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... none
checking for python... /afs/slac/g/lcls/package/python/current/bin/python
checking for a version of Python >= '2.1.0'... yes
checking for a version of Python >=2.6... yes
checking for the distutils Python package... yes
checking for Python include path... -I/afs/slac/g/lcls/package/python/current/include/python2.7
checking for Python library path... -L/afs/slac/g/lcls/package/python/Python-2.7.4/lib -lpython2.7
checking for Python site-packages path... /afs/slac/g/lcls/package/python/current/lib/python2.7/site-packages
checking python extra libraries... -lpthread -ldl  -lutil
checking python extra linking flags... -Xlinker -export-dynamic
checking consistency of all components of python development environment... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... none
checking for boostlib >= 1.40... configure: We could not detect the boost libraries (version 1.40 or higher). If you have a staged boost library (still not installed) please specify $BOOST_ROOT in your environment and do not give a PATH to --with-boost option.  If you are sure you have boost installed, then check your version number looking in <boost/version.hpp>. See http://randspringer.de/boost for more documentation.
configure: error: required Boost library version >= 1.40.
make: *** [configure] Error 1
**************  Output of CONFIG_SITE.local ****************************************************************************
[ernesto@lcls-dev2 configure]$ more CONFIG_SITE.local
PACKAGE_TOP=/afs/slac/g/lcls/package
PYTHON_TOP=$(PACKAGE)/python/current
BOOST_DIR=$(PACKAGE)/boost/1.58.0/linux-x86
PVA_PY_CPPFLAGS=-I$(BOOST_DIR)/include -I$(PYTHON_TOP)/include/python2.7
PVA_PY_LDFLAGS=-L$(BOOST_DIR)/lib -L$(PYTHON_TOP)/lib -lpython2.7
Cheers,
Ernest
Sinisa
On 08/12/2015 01:08 AM, Williams Jr., Ernest L. wrote:
I am working with EPICS V4 and would like to build the python support (i.e. "pvaPy")
HOST = RHEL5 32-bit,  linux-x86
Indeed, I have configured/built the necessary dependent external packages
(1) Boost  ==>  1.58.0
(2) Python ==> 2.7.4
The EPICS V4 release ==> base-cpp-R4-4-0-pre2
The EPICS BASE V3 release ==> base-R3-14-12
pvaPy"
All of the V4 modules build nicely, except that I have the following problem with "pvaPy"
Any help or solutions, appreciated:
../RpcClient.cpp:82: error: 'response' was not declared in this scope
======================= Compile Error Below ============================================
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -MMD -g -I/afs/slac/g/lcls/package/boost/1.58.0/linux-x86/include -I//afs/slac/g/lcls/package/python/current/include/python2.7 -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include   -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include/os/Linux -I/afs/slac/g/lcls/epics/base/base-R3-14-12/include  -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvDataCPP/include  -I/afs/slac/g/lcls/epics/base/base-cpp-R4-4-0-pre2/pvAccessCPP/include       ../RpcClient.cpp
../RpcClient.cpp: In static member function 'static std::tr1::shared_ptr<epics::pvAccess::RPCClient> RpcClient::createRpcClient(const std::string&, const epics::pvData::PVStructurePtr&, double)':
../RpcClient.cpp:53: warning: no return statement in function returning non-void
../RpcClient.cpp: In member function 'virtual std::tr1::shared_ptr<epics::pvData::PVStructure> RpcClient::request(const epics::pvData::PVStructurePtr&, double)':
make[1]: *** [RpcClient.o] Error 1
make: *** [install.linux-x86] Error 2
Sinisa Veseli
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]
(630)252-9182
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
[email protected]
(630)252-9182
Sinisa Veseli
[email protected]
(630)252-9182
Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Williams Jr., Ernest L.
Re: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Sinisa Veseli
RE: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Williams Jr., Ernest L.
Prev: RE: Error building EPICS V4 "pvaPy" : RpcClient.cpp:82: error: 'response' was not declared in this scope Williams Jr., Ernest L.
Next: Job opportunity at PSI Kalantari Babak (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: LeCroy 1440 HV Support Jiro Fujita
