1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Records for slow control
To: "[email protected]" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 27 Aug 2015 17:32:43 +0000
You don't actually have to stop the calc record.  You could just stop the value from increasing.
The following _expression_ holds the increasing value in the 'a' field, and increases it by 'b' until
it reaches 'c'.  Then it returns the value of 'a' as the _expression_ result.
a:=((a+b)>c?c:a+b); a
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Thursday, August 27, 2015 12:16 PM
To: EPICS Tech-Talk
Subject: AW: Records for slow control
Hello,
and how can I stop a calc record?
I want to set a new value like 100, 200, 300 V.... then I want to compare this value with the current value and increase or decrease this value every 10 seconds in 5V-steps. ‎Maybe someone have an idea. One problem is to stop the calc record if current value = new value.
Thanks.
Von: Mooney, Tim M.
Gesendet: Mittwoch, 26. August 2015 17:20
An: [email protected]; EPICS Tech-Talk
Betreff: RE: Records for slow control
There are two databases in the synApps std module that demonstrate different ways of doing this with EPICS records:
std/stdApp/Db/timer.*
std/stdApp/op/adl/timer.*
std/stdApp/Db/countDownTmer.*
std/stdApp/op/adl/countDownTimer.*
Sent: Wednesday, August 26, 2015 5:09 AM
To: EPICS Tech-Talk
Hello,
but I want to increase the value for example every hour. The time have to be variable so I need a calcout timer to count for example every 10 second from 0 to ‎50 and then to increase the value step by step. My problem is how to realise  this with two records. One have to increase +1, then go to the timer record and wait for example one hour set value and again: increase +1, then process timer or counter for slowly periodic scan, set value.
Thanks.
Von: Ralph Lange
Gesendet: Mittwoch, 26. August 2015 11:58
An: EPICS Tech-Talk
Betreff: Re: Records for slow control
On 26/08/2015 11:39, [email protected] wrote:
Hello,
I want to set a value like 200 ampere and increase the current value slowly but how?
I have a timer-record with a PROC field with the option "transition to zero". A second record increase the value every time. Is it possible to create records like this:
• Calcout1 timer: scan every second from 1 to 10
• -» then process Calcout2 (via PROC field, without SCAN field) from 1 to 3
• Calcout2 have to wait, process Calcout1 again...
In the ao record that is setting your value, set the field SCAN to "1 second" (or how often you want to "slowly" update) and the field OROC to the step size that you want to the value to change every time (e.g. 0.1).
No other records needed.
Now, when you write a value like 200 to that record, the output will step up by 0.1 every second. (Or whatever step size and update rate you configured.)
Hope this helps,
~Ralph
AW: Records for slow control info22
Re: Records for slow control Maren Purves
Re: Records for slow control info22
Re: Records for slow control Ralph Lange
RE: Records for slow control Mooney, Tim M.
Prev: AW: Records for slow control info22
Next: AW: Records for slow control info22
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
