1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Records for slow control
To: [email protected]
Date: Thu, 27 Aug 2015 10:12:44 -1000
If you really want to stop it instead you could set it to process PASSIVE.
Maren
On 08/27/15 07:32, Mooney, Tim M. wrote:
You don't actually have to stop the calc record.  You could just stop
the value from increasing.
The following expression holds the increasing value in the 'a' field,
and increases it by 'b' until
it reaches 'c'.  Then it returns the value of 'a' as the expression result.
a:=((a+b)>c?c:a+b); a
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
behalf of [email protected] [[email protected]]
*Sent:* Thursday, August 27, 2015 12:16 PM
*To:* EPICS Tech-Talk
*Subject:* AW: Records for slow control
Hello,
and how can I stop a calc record?
I want to set a new value like 100, 200, 300 V.... then I want to
compare this value with the current value and increase or decrease this
value every 10 seconds in 5V-steps. ‎Maybe someone have an idea. One
problem is to stop the calc record if current value = new value.
Thanks.
*Von: *Mooney, Tim M.
*Gesendet: *Mittwoch, 26. August 2015 17:20
*An: *[email protected]; EPICS Tech-Talk
*Betreff: *RE: Records for slow control
There are two databases in the synApps std module that demonstrate
different ways of doing this with EPICS records:
std/stdApp/Db/timer.*
std/stdApp/op/adl/timer.*
std/stdApp/Db/countDownTmer.*
std/stdApp/op/adl/countDownTimer.*
*Sent:* Wednesday, August 26, 2015 5:09 AM
Hello,
but I want to increase the value for example every hour. The time have
to be variable so I need a calcout timer to count for example every 10
second from 0 to ‎50 and then to increase the value step by step. My
problem is how to realise  this with two records. One have to increase
+1, then go to the timer record and wait for example one hour set value
and again: increase +1, then process timer or counter for slowly
periodic scan, set value.
Thanks.
*Von: *Ralph Lange
*Gesendet: *Mittwoch, 26. August 2015 11:58
*An: *EPICS Tech-Talk
*Betreff: *Re: Records for slow control
On 26/08/2015 11:39, [email protected] wrote:
Hello,
I want to set a value like 200 ampere and increase the current value
slowly but how?
I have a timer-record with a PROC field with the option "transition to
zero". A second record increase the value every time. Is it possible
to create records like this:
• Calcout1 timer: scan every second from 1 to 10
• -» then process Calcout2 (via PROC field, without SCAN field) from 1
to 3
• Calcout2 have to wait, process Calcout1 again...
In the ao record that is setting your value, set the field SCAN to "1
second" (or how often you want to "slowly" update) and the field OROC to
the step size that you want to the value to change every time (e.g. 0.1).
No other records needed.
Now, when you write a value like 200 to that record, the output will
step up by 0.1 every second. (Or whatever step size and update rate you
configured.)
Hope this helps,
~Ralph
Re: Records for slow control info22
Re: Records for slow control Ralph Lange
AW: Records for slow control info22
RE: Records for slow control Mooney, Tim M.
Prev: AW: Records for slow control info22
Next: Virtual Circuit Disconnect Warning Deepika Thakur
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: AW: Records for slow control info22
