1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Serial port COM10: not work?
Cc: "EPICS Tech-Talk \([email protected]\)" <[email protected]>
Date: Wed, 30 Sep 2015 11:18:41 -0700
On Sep 30, 2015, at 10:31 AM, Mark Rivers <[email protected]> wrote:
The code in question is in the Windows-specific driver file (drvAsynSerialPortWin32.c), so it is already Windows-specific.  We are not adding OS-specific code to a generic driver.
Oops — I forgot that windows didn’t use the Posix termios code.
I don’t like users having to put 6 backslash characters into the device name, where everywhere else in Windows they just say COM10.
I agree with Peter’s suggestion that we don’t need a special case for COM1-COM9.
I propose the following:
-          If the device name passed to drvAsynSerialPortConfigure starts with  ‘\’  then assume the user has used a device name, and use it directly.
-          If the device name does not begin with ‘\’ then prepend “\\.\”.
That sounds ideal.
Eric Norum
[email protected]
Re: Serial port COM10: not work? Torsten Bögershausen
Serial port COM10: not work? Heesterman, Peter J
Re: Serial port COM10: not work? Jack
RE: Serial port COM10: not work? Mark Rivers
Re: Serial port COM10: not work? Eric Norum
Prev: RE: Serial port COM10: not work? Mark Rivers
Next: RE: New sequencer releases Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Serial port COM10: not work? Torsten Bögershausen
