1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Building Epics base 3.15.2 in Windows 7
To: "'Klyachko, Alexander Vitalievich'" <[email protected]>, "'Andrew Johnson'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 9 Nov 2015 19:10:29 +0000
I get the same error building base 3.15.2 with the Visual Studio 2015 Community Edition on both win32-x86 and windows-x64.
cl -EHsc -GR                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/msvc -I../../../../include/os/WIN32 -I../../../../include         -c ../epicsExceptionTest.cpp
../epicsExceptionTest.cpp(59): error C2148: total size of array must not exceed 0x7fffffff bytes
../epicsExceptionTest.cpp(72): error C2148: total size of array must not exceed 0x7fffffff bytes
../../../../configure/RULES_BUILD:228: recipe for target 'epicsExceptionTest.obj' failed
make[3]: *** [epicsExceptionTest.obj] Error 2
make[3]: Leaving directory 'C:/EPICS/base-3.15.2/src/libCom/test/O.windows-x64'
../../../configure/RULES_ARCHS:61: recipe for target 'install.windows-x64' failed
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory 'C:/EPICS/base-3.15.2/src/libCom/test'
../configure/RULES_DIRS:88: recipe for target 'libCom/test.install' failed
make[1]: *** [libCom/test.install] Error 2
make[1]: Leaving directory 'C:/EPICS/base-3.15.2/src'
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
make[3]: Leaving directory 'C:/EPICS/base-3.15.2/src/libCom/test/O.win32-x86'
../../../configure/RULES_ARCHS:61: recipe for target 'install.win32-x86' failed
make[2]: *** [install.win32-x86] Error 2
-----Original Message-----
From: Klyachko, Alexander Vitalievich [mailto:[email protected]]
Sent: Monday, November 09, 2015 12:28 PM
To: Mark Rivers; 'Pete Jemian'; [email protected]
Subject: Re: Building Epics base 3.15.2 in Windows 7
That worked very well - well, almost.
I installed VC++ support, now have vcvarsall.bat. Using it, make now get much farther, but I still get an error message:
Generating code
Finished generating code
make[3]: Leaving directory `c:/base-3.15.2/src/libCom/test/O.win32-x86'
make[2]: Leaving directory `c:/base-3.15.2/src/libCom/test'
make[1]: Leaving directory `c:/base-3.15.2/src'
Alex.
Sent: Saturday, November 7, 2015 11:57 AM
To: 'Pete Jemian'; [email protected]; Klyachko, Alexander Vitalievich
I figured out my problem. I had not configured Visual Studio 2015 to have the VC++ language support.
I fixed this using Control Panel/Programs and Features/Microsoft Visual Studio 2015/Change and selected Modify.  I then checked the box for Programming Languages/VC++.  Once I did that then many more .bat files appeared, including Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat.
Alexander also reported that he did not have a vcvarsall.bat file on his system, so I suspect he has the same problem I did, and also needs to install the VC++ support in Visual Studio.  I think that once vcvarsall.bat is run from the cmd window startup that the EPICS build errors will be fixed.
Sent: Friday, November 06, 2015 5:05 PM
My installation is missing the vcvars64.bat and vcvarsall.bat files.  Perhaps some incorrect choice I made during installation?  Mine is also a new installation of 2015 Community, and I have not tried to use it either.
From: [email protected] [mailto:[email protected]] On Behalf Of Pete Jemian
Sent: Friday, November 06, 2015 5:01 PM
To: [email protected]
perhaps this?
D:\Program Files (x86)\Microsoft Visual Studio
14.0\VC\bin\amd64\vcvars64.bat
and what about this?
D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat
On 11/6/2015 4:38 PM, Mark Rivers wrote:
> C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\Tools\vxvars32.bat
> But that file is only for 32-bit builds.  I can't find a batch file for defining things for 64-bit builds.
> Alexander, do you have a file for doing 64-bit builds on your system?
> Mark
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
    Education is the one thing for which people
       are willing to pay yet not receive.
Re: Building Epics base 3.15.2 in Windows 7 Bob Soliday
Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
RE: Building Epics base 3.15.2 in Windows 7 Mark Rivers
Re: Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
RE: Building Epics base 3.15.2 in Windows 7 Mark S. Engbretson
Re: Building Epics base 3.15.2 in Windows 7 Pete Jemian
Prev: Re: Building Epics base 3.15.2 in Windows 7 Klyachko, Alexander Vitalievich
Next: Re: Building Epics base 3.15.2 in Windows 7 Bob Soliday
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
